Maniphest T94868
[Windows] With Microsoft IME PinYin, when it input "0" with fullwidth at text edit, it gets "00".
Closed, Resolved
Harley Acheson (harley)
Takahiro Shizuki (sntulix)
Jan 13 2022, 10:17 AM
  • Platform: Windows
  • BF Blender
  • User Interface
Philipp Oeser (lichtwerk)
Yuki Hashimoto (hzuika)
platform: 'Windows-10-10.0.19043-SP0'
renderer: 'Intel(R) Iris(TM) Graphics 5100'
Broken:
version: 3.1.0 Alpha, branch: master, commit date: 2022-01-12 19:46, hash: 97c2c3991620, type: release
build date: 2022-01-13, 00:56:32
With Microsoft IME PinYin with set fullwidth by IME toolbar, when it input "0" at text edit, it gets "00".
Revisions and Commits
rB Blender
D14354
Takahiro Shizuki (sntulix) created this task.Jan 13 2022, 10:17 AM
Philipp Oeser (lichtwerk) added a project: BF Blender.Mar 10 2022, 8:55 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from Developers.Mar 10 2022, 9:09 AM
Philipp Oeser (lichtwerk) added a project: User Interface.
@Harley Acheson (harley) : can you confirm (not on Windows here)?
Harley Acheson (harley) added a comment.Mar 13 2022, 10:56 PM
@Takahiro Shizuki (sntulix) - Are you able to give some more information on what is the expected behavior and use case for this?
I realize that current behavior is wrong in some way. When pressing “0” (on main keyboard or numpad) while in Pinyin in "fullwidth" mode you get "00", which is a regular zero (U+0030) followed by a fullwidth zero (U+FF10).
First note that this bug report applies to all number characters from 0-9, not just 0. Are you wanting keypresses while in fullwidth mode to insert fullwidth characters? Is this useful?
The fullwidth zero is not the same character as regular zero so there are lots of considerations. Would you want to enter fullwidth 3 into a numerical fields and be treated as 3? Or ignored?
When using these fullwidth numbers in names they won't sort correctly. I eventually want to do proper international sorting using the Unicode Collation algorithm (probably using ICU - International Components for Unicode), but that won't happen any time soon.
When using these fullwidth numbers in object names we won't be able to keep visual uniqueness or deal with their use in bones, etc. For example right now you can only have a single object called "Cube.001", but with these characters you could have a "Cube.001", "Cube.001", "Cube.001", etc. When duplicating "Cube.001" now we make a new one as ""Cube.002" but that can't happen with "Cube.001" and I think you'd get something like ""Cube.001.001"
So I guess I am just wanting to clarify what is needed, what is expected, etc
Takahiro Shizuki (sntulix) added a comment.EditedMar 14 2022, 4:31 AM
Hi. @Harley Acheson (harley)
I don't expect a something about this. Because I'm not a End User of Chinese Language.
Also this is a just reporting I found.
Is this useful?
I think this has two points. The one is fullwidth inputting has used at Name in all around (in Japan) and it exists as a usable character in a character set. Another point is Auto naming rule of Object when duplicated ("Cube.001", "Cube.002").
But I think its are not same background problem. The one is a Language Problem on Computer, another is Blender's usability.
About 0-9 (fullwidth numeric): /* This is just think. */
The function auto converting the fullwidth to the halfwidth is useful at Numeric edit box. But if when 0-9 is used in a document like the naming specifications,
the auto converting is not useful in Text edit box, Because it is unlike previous, inconsistent. It could be a problem.
UPDATE:
If when I needed 0-9 (fullwidth) at Text edit box, I use "copy & paste" or negotiation with a customer.
Harley Acheson (harley) added a commit: rB82c852f38732: Fix D14173: Chinese IME Full Width Numbers.Mar 19 2022, 5:06 PM
Harley Acheson (harley) closed this task as Resolved.Mar 19 2022, 5:08 PM
Harley Acheson (harley) claimed this task.
