Maniphest T94878
Line Art: Per object Override Crease setting does not work
Closed, Resolved
YimingWu (NicksBest)
Elias Schwarze (eschwarze)
Jan 13 2022, 1:39 PM
  • BF Blender
  • Line Art
Pratik Borhade (PratikPB2123)
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.68
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Caused by rBc1cf66bff3c0: LineArt: Automatic crease with flat/smooth faces.
When using the Line Art modifier to generate Outlines for a 3D Mesh, the "Override Crease" option in the object properties of each object does not affect line generation at all.
  • Open attached .blend file
  • Switch to camera view
  • Select the Suzanne object
  • Go to the Line Art Panel in object properties
  • Activate the "Override Crease" option and increase or decrease the crease angle slider
  • This should generate either more or less outlines based on the angles of the individual polygons, however it does not appear to do anything
Revisions and Commits
rB Blender
Related Objects
Mentioned In
T93479: 3.0 Potential candidates for corrective releases
Mentioned Here
rB0cf746c1faff: Fix T94878: LineArt crease threshold logic error.
Elias Schwarze (eschwarze) created this task.Jan 13 2022, 1:39 PM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Jan 14 2022, 7:07 AM
Pratik Borhade (PratikPB2123) added a project: Line Art.
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Thanks for the report. I can confirm on current master.
Will bisect.
Pratik Borhade (PratikPB2123) triaged this task as High priority.Jan 14 2022, 10:10 AM
Pratik Borhade (PratikPB2123) added a subscriber: YimingWu (NicksBest).
Hi @YimingWu (NicksBest), can you look at this issue? Was appeared in rBc1cf66bff3c0: LineArt: Automatic crease with flat/smooth faces.
Regression and culprit commit is known so I am raising the priority (feel free to change)
Pratik Borhade (PratikPB2123) updated the task description.Jan 14 2022, 10:11 AM
YimingWu (NicksBest) claimed this task.Jan 14 2022, 1:59 PM
Hi I'll take a look.
YimingWu (NicksBest) closed this task as Resolved by committing rB0cf746c1faff: Fix T94878: LineArt crease threshold logic error..Jan 14 2022, 2:44 PM
YimingWu (NicksBest) added a commit: rB0cf746c1faff: Fix T94878: LineArt crease threshold logic error..
Hi I have fixed the problem in master with 0cf746c1faff31e6e97789ffdd46206112ac81db.
Philipp Oeser (lichtwerk) added a commit: rB5079a460a748: Fix T94878: LineArt crease threshold logic error..Jan 17 2022, 1:25 PM
