Maniphest T95098
Loop Cut tool applies multiple Undo commands
Closed, Duplicate
None
nick harper (reprahkcin)
Jan 20 2022, 11:27 PM
  • BF Blender
Pratik Borhade (PratikPB2123)
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.23
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
using loop cut tool, and using the panel to add additional cuts, results in an instant application of around a dozen undo operations. I can 'redo' back up to before the loop cut.
create a plane, use the loop cut tool to add one cut. Use the Loop Cut and Slide panel to add cuts and adjust Falloff and Factor. Then everything disappears and I'm left around a dozen steps back in my history.
nick harper (reprahkcin) created this task.Jan 20 2022, 11:27 PM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Jan 21 2022, 4:24 AM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Jan 21 2022, 4:31 AM
Hi, Thanks for the report. Cannot reproduce by just changing values from Redo panel (tested on 3.0.0 and current master).
Did you use Reset to Defaults from context menu? Reminds me this issue: T93629: Regression: Reset To Default Value undoing everything when applied twice in the same menu.
Can you make a screen recoding to show the problem?
Pratik Borhade (PratikPB2123) updated the task description.Jan 21 2022, 4:31 AM
nick harper (reprahkcin) added a comment.Jan 25 2022, 12:51 AM
You are correct, Pratik, the "Reset to Defaults" command is what was triggering the undos.
Pratik Borhade (PratikPB2123) added a comment.Jan 25 2022, 1:47 AM
Thanks for clarifying. Will merge into other report.
Thanks again for the report!
