Maniphest T95354
Bug with screen/light/shadow
Closed, Archived
None
Damian (Damiandad1)
Jan 31 2022, 12:30 PM
  • BF Blender
Damian (Damiandad1)
Richard Antalik (ISS)
Operating system: Windows 10
Graphics card: GTX 1050 Ti (Laptop)
Broken: 3.0. Strange shadows
Worked: Changing to the older version 2.93
It appears when I am moving mouse outside the main viewport. Strange shadows which are changing, it cannot be recorded but I am seeing this on my screen
I just changed blender version to 3.0 and darken theme, on bright theme it doesn't appear
Related Objects
Damian (Damiandad1) created this task.Jan 31 2022, 12:30 PM
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Feb 1 2022, 4:19 AM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
Can you check if this happens with latest alpha build from https://builder.blender.org/download/daily/?
Seems similar to T93875, can you check if you can follow discussion and whether that does resolve this issue?
Damian (Damiandad1) added a comment.Feb 1 2022, 11:48 AM
Problem solved after changing gradient color in 3D Viewport to single color.
Richard Antalik (ISS) closed this task as Archived.Feb 1 2022, 11:46 PM
Thanks for update, will close then.
