Operating system: MacOS 12.1 Monterey
Graphics card: AMD Radeon RX Vega 56 8 GB
Broken: (example: 3.1 Beta (latest/greatest as of Feb 3, 2022)
"Boom!" happens when I try weight-paint something, using particle system. Problem is that it does not happen all the time, so reproducing is tough.
| 1 | |
| 2 | ------------------------------------- |
| 3 | Translated Report (Full Report Below) |
| 4 | ------------------------------------- |
| 5 | |
| 6 | Process: Blender [2869] |
| 7 | Path: /Applications/Blender/Blender.app/Contents/MacOS/Blender |
| 8 | Identifier: org.blenderfoundation.blender |
| 9 | Version: 3.1.0 (3.1.0 2022-01-31) |
| 10 | Code Type: X86-64 (Native) |
| 11 | Parent Process: launchd [1] |
| 12 | User ID: 501 |
| 13 | |
| 14 | Date/Time: 2022-02-03 22:04:35.9928 +0100 |
| 15 | OS Version: macOS 12.1 (21C52) |
| 16 | Report Version: 12 |
| 17 | Bridge OS Version: 6.1 (19P647) |
| 18 | Anonymous UUID: 229ABBC2-C318-7915-FA97-7BBEFE9A75FB |
| 19 | |
| 20 | |
| 21 | Time Awake Since Boot: 37000 seconds |
| 22 | |
| 23 | System Integrity Protection: enabled |
| 24 | |
| 25 | Crashed Thread: 0 Dispatch queue: com.apple.main-thread |
| 26 | |
| 27 | Exception Type: EXC_BAD_ACCESS (SIGSEGV) |
| 28 | Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000000c8 |
| 29 | Exception Codes: 0x0000000000000001, 0x00000000000000c8 |
| 30 | Exception Note: EXC_CORPSE_NOTIFY |
| 31 | |
| 32 | Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11 |
| 33 | Terminating Process: exc handler [2869] |
| 34 | |
| 35 | VM Region Info: 0xc8 is not in any region. Bytes before following region: 4449857336 |
| 36 | REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL |
| 37 | UNUSED SPACE AT START |
| 38 | ---> |
| 39 | __TEXT 1093b7000-115cef000 [201.2M] r-x/r-x SM=COW ...MacOS/Blender |
| 40 | |
| 41 | ID Vend/Dev |
| 42 | 8938 687f1002 |
| 43 | Seconds Ago ID Type |
| 44 | 37000.0 8938 Attach |
| 45 | |
| 46 | |
| 47 | Kernel Triage: |
| 48 | VM - Fault hit memory shortage |
| 49 | VM - Fault hit memory shortage |
| 50 | VM - Fault hit memory shortage |
| 51 | VM - Fault hit memory shortage |
| 52 | VM - Fault hit memory shortage |
| 53 | |
| 54 | |
| 55 | Thread 0 Crashed:: Dispatch queue: com.apple.main-thread |
| 56 | 0 GLEngine 0x7ffa2fd16da5 gleUpdateCtxDirtyStateForBufStampChange + 340 |
| 57 | 1 GLEngine 0x7ffa2fd17d21 gleBindBufferObject + 3249 |
| 58 | 2 GLEngine 0x7ffa2fc7210b glBindBuffer_Exec + 128 |
| 59 | 3 Blender 0x111e8f876 blender::gpu::GLUniformBuf::update(void const*) + 118 |
| 60 | 4 Blender 0x109c6e365 DRW_globals_update + 2629 |
| 61 | 5 Blender 0x109c72f39 DRW_draw_render_loop_ex + 569 |
| 62 | 6 Blender 0x10a7ae38a view3d_main_region_draw + 138 |
| 63 | 7 Blender 0x10a0708c1 ED_region_do_draw + 337 |
| 64 | 8 Blender 0x109af73ed wm_draw_update + 1757 |
| 65 | 9 Blender 0x109af4920 WM_main + 48 |
| 66 | 10 Blender 0x109533fc9 main + 873 |
| 67 | 11 dyld 0x12a5454fe start + 462 |
| 68 | |
| 69 | Thread 1: |
| 70 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 71 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 72 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 73 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 74 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 75 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 76 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 77 | |
| 78 | Thread 2: |
| 79 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 80 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 81 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 82 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 83 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 84 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 85 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 86 | |
| 87 | Thread 3: |
| 88 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 89 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 90 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 91 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 92 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 93 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 94 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 95 | |
| 96 | Thread 4: |
| 97 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 98 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 99 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 100 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 101 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 102 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 103 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 104 | |
| 105 | Thread 5: |
| 106 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 107 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 108 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 109 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 110 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 111 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 112 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 113 | |
| 114 | Thread 6: |
| 115 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 116 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 117 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 118 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 119 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 120 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 121 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 122 | |
| 123 | Thread 7: |
| 124 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 125 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 126 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 127 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 128 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 129 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 130 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 131 | |
| 132 | Thread 8: |
| 133 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 134 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 135 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 136 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 137 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 138 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 139 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 140 | |
| 141 | Thread 9: |
| 142 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 143 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 144 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 145 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 146 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 147 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 148 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 149 | |
| 150 | Thread 10: |
| 151 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 152 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 153 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 154 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 155 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 156 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 157 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 158 | |
| 159 | Thread 11: |
| 160 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 161 | 1 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16 |
| 162 | 2 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98 |
| 163 | 3 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79 |
| 164 | 4 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62 |
| 165 | 5 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 166 | 6 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 167 | |
| 168 | Thread 12:: AMCP Logging Spool |
| 169 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 170 | 1 caulk 0x7ff8207cf1c0 caulk::mach::semaphore::wait_or_error() + 16 |
| 171 | 2 caulk 0x7ff8207b608a caulk::concurrent::details::worker_thread::run() + 36 |
| 172 | 3 caulk 0x7ff8207b5d4e void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 41 |
| 173 | 4 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 174 | 5 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 175 | |
| 176 | Thread 13:: com.apple.audio.IOThread.client |
| 177 | 0 libsystem_kernel.dylib 0x7ff817d0eaba mach_msg_trap + 10 |
| 178 | 1 libsystem_kernel.dylib 0x7ff817d0ee2b mach_msg + 59 |
| 179 | 2 CoreAudio 0x7ff81999295b HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111 |
| 180 | 3 CoreAudio 0x7ff8198210ff HALC_ProxyIOContext::IOWorkLoop() + 3937 |
| 181 | 4 CoreAudio 0x7ff81981fbc1 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 63 |
| 182 | 5 CoreAudio 0x7ff8199e876c HALB_IOThread::Entry(void*) + 72 |
| 183 | 6 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 184 | 7 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 185 | |
| 186 | Thread 14: |
| 187 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 188 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 189 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 190 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 191 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 192 | |
| 193 | Thread 15: |
| 194 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 195 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 196 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 197 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 198 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 199 | |
| 200 | Thread 16: |
| 201 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 202 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 203 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 204 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 205 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 206 | |
| 207 | Thread 17: |
| 208 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 209 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 210 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 211 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 212 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 213 | |
| 214 | Thread 18: |
| 215 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 216 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 217 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 218 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 219 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 220 | |
| 221 | Thread 19: |
| 222 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 223 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 224 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 225 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 226 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 227 | |
| 228 | Thread 20: |
| 229 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 230 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 231 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 232 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 233 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 234 | |
| 235 | Thread 21: |
| 236 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 237 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 238 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 239 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 240 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 241 | |
| 242 | Thread 22: |
| 243 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 244 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 245 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 246 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 247 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 248 | |
| 249 | Thread 23: |
| 250 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 251 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 252 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 253 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 254 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 255 | |
| 256 | Thread 24: |
| 257 | 0 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10 |
| 258 | 1 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344 |
| 259 | 2 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9 |
| 260 | 3 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 261 | 4 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 262 | |
| 263 | Thread 25: |
| 264 | 0 libsystem_kernel.dylib 0x7ff817d15196 __accept + 10 |
| 265 | 1 _socket.cpython-310-darwin.so 0x123d46388 sock_accept_impl + 24 |
| 266 | 2 _socket.cpython-310-darwin.so 0x123d467e2 sock_call_ex + 402 |
| 267 | 3 _socket.cpython-310-darwin.so 0x123d44080 sock_accept + 144 |
| 268 | 4 Blender 0x111f60247 method_vectorcall_NOARGS + 135 |
| 269 | 5 Blender 0x11204b5df call_function + 431 |
| 270 | 6 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501 |
| 271 | 7 Blender 0x112040d01 _PyEval_Vector + 145 |
| 272 | 8 Blender 0x11204b5df call_function + 431 |
| 273 | 9 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501 |
| 274 | 10 Blender 0x112040d01 _PyEval_Vector + 145 |
| 275 | 11 Blender 0x11204b5df call_function + 431 |
| 276 | 12 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501 |
| 277 | 13 Blender 0x112040d01 _PyEval_Vector + 145 |
| 278 | 14 Blender 0x11204b5df call_function + 431 |
| 279 | 15 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501 |
| 280 | 16 Blender 0x112040d01 _PyEval_Vector + 145 |
| 281 | 17 Blender 0x111f590bf method_vectorcall + 367 |
| 282 | 18 Blender 0x1120f4da6 thread_run + 70 |
| 283 | 19 Blender 0x1120a5229 pythread_wrapper + 25 |
| 284 | 20 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 285 | 21 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 286 | |
| 287 | Thread 26: |
| 288 | 0 libsystem_kernel.dylib 0x7ff817d16e4a __select + 10 |
| 289 | 1 Blender 0x1120f330c time_sleep + 140 |
| 290 | 2 Blender 0x111f9ce85 cfunction_vectorcall_O + 277 |
| 291 | 3 Blender 0x11204b5df call_function + 431 |
| 292 | 4 Blender 0x11204857a _PyEval_EvalFrameDefault + 30538 |
| 293 | 5 Blender 0x112040d01 _PyEval_Vector + 145 |
| 294 | 6 Blender 0x11204b5df call_function + 431 |
| 295 | 7 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501 |
| 296 | 8 Blender 0x112040d01 _PyEval_Vector + 145 |
| 297 | 9 Blender 0x11204b5df call_function + 431 |
| 298 | 10 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501 |
| 299 | 11 Blender 0x112040d01 _PyEval_Vector + 145 |
| 300 | 12 Blender 0x111f590bf method_vectorcall + 367 |
| 301 | 13 Blender 0x1120f4da6 thread_run + 70 |
| 302 | 14 Blender 0x1120a5229 pythread_wrapper + 25 |
| 303 | 15 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 304 | 16 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 305 | |
| 306 | Thread 27:: com.apple.NSEventThread |
| 307 | 0 libsystem_kernel.dylib 0x7ff817d0eaba mach_msg_trap + 10 |
| 308 | 1 libsystem_kernel.dylib 0x7ff817d0ee2b mach_msg + 59 |
| 309 | 2 CoreFoundation 0x7ff817e12af2 __CFRunLoopServiceMachPort + 319 |
| 310 | 3 CoreFoundation 0x7ff817e111cb __CFRunLoopRun + 1325 |
| 311 | 4 CoreFoundation 0x7ff817e105dd CFRunLoopRunSpecific + 563 |
| 312 | 5 AppKit 0x7ff81a9add98 _NSEventThread + 132 |
| 313 | 6 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 314 | 7 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 315 | |
| 316 | Thread 28: |
| 317 | 0 libsystem_kernel.dylib 0x7ff817d16e4a __select + 10 |
| 318 | 1 Blender 0x1120f330c time_sleep + 140 |
| 319 | 2 Blender 0x111f9ce85 cfunction_vectorcall_O + 277 |
| 320 | 3 Blender 0x11204b5df call_function + 431 |
| 321 | 4 Blender 0x11204857a _PyEval_EvalFrameDefault + 30538 |
| 322 | 5 Blender 0x112040d01 _PyEval_Vector + 145 |
| 323 | 6 Blender 0x11204b5df call_function + 431 |
| 324 | 7 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501 |
| 325 | 8 Blender 0x112040d01 _PyEval_Vector + 145 |
| 326 | 9 Blender 0x11204b5df call_function + 431 |
| 327 | 10 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501 |
| 328 | 11 Blender 0x112040d01 _PyEval_Vector + 145 |
| 329 | 12 Blender 0x111f590bf method_vectorcall + 367 |
| 330 | 13 Blender 0x1120f4da6 thread_run + 70 |
| 331 | 14 Blender 0x1120a5229 pythread_wrapper + 25 |
| 332 | 15 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125 |
| 333 | 16 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15 |
| 334 | |
| 335 | Thread 29: |
| 336 | 0 libsystem_pthread.dylib 0x7ff817d46fec start_wqthread + 0 |
| 337 | |
| 338 | Thread 30: |
| 339 | 0 libsystem_pthread.dylib 0x7ff817d46fec start_wqthread + 0 |
| 340 | |
| 341 | Thread 31: |
| 342 | 0 libsystem_pthread.dylib 0x7ff817d46fec start_wqthread + 0 |
| 343 | |
| 344 | Thread 32: |
| 345 | 0 libsystem_pthread.dylib 0x7ff817d46fec start_wqthread + 0 |
| 346 | |
| 347 | |
| 348 | Thread 0 crashed with X86 Thread State (64-bit): |
| 349 | rax: 0x00007fd37178f520 rbx: 0x00007fd4df74e000 rcx: 0x0000000000000000 rdx: 0x00000000fff9ae96 |
| 350 | rdi: 0x00000000fffff676 rsi: 0x0000000000000050 rbp: 0x00007ff7b6b47040 rsp: 0x00007ff7b6b47020 |
| 351 | r8: 0x0000000000000000 r9: 0x00007fd4da0e2ab0 r10: 0x00000000000007fb r11: 0x00000000055196d8 |
| 352 | r12: 0x0000000000000001 r13: 0x00007fd4df74e000 r14: 0x0000000000000001 r15: 0x0000000000000009 |
| 353 | rip: 0x00007ffa2fd16da5 rfl: 0x0000000000010206 cr2: 0x00000000000000c8 |
| 354 | |
| 355 | Logical CPU: 2 |
| 356 | Error Code: 0x00000004 (no mapping for user data read) |
| 357 | Trap Number: 14 |
| 358 | |
| 359 | Thread 0 instruction stream: |
| 360 | 00 85 ff 7f 0a 48 ff c6-48 39 f1 75 df eb 1f 80 .....H..H9.u.... |
| 361 | 88 a0 1a 00 00 10 80 8b-ff 05 00 00 30 c7 83 bc ............0... |
| 362 | ae 00 00 00 00 00 00 80-8b 07 06 00 00 10 4c 8b ..............L. |
| 363 | b3 88 8d 00 00 4d 85 f6-0f 84 84 00 00 00 45 31 .....M........E1 |
| 364 | ff 41 bc 01 00 00 00 41-f6 c6 01 74 6d 49 6b c7 .A.....A...tmIk. |
| 365 | 58 48 8b 84 03 08 61 00-00 48 8b 88 38 02 00 00 XH....a..H..8... |
| 366 | [8b]89 c8 00 00 00 2b 8b-2c b6 00 00 85 c9 7e 4a ......+.,.....~J <== |
| 367 | 48 8d 70 28 0f b6 8b a1-c6 00 00 85 c9 74 1f 41 H.p(.........t.A |
| 368 | 0f 44 cc 48 c1 e1 03 48-8d 0c 49 31 d2 80 8c 10 .D.H...H..I1.... |
| 369 | 9c 00 00 00 08 48 83 c2-18 48 39 d1 75 ef c7 83 .....H...H9.u... |
| 370 | bc ae 00 00 00 00 00 00-81 8b 0c 06 00 00 00 20 ............... |
| 371 | 02 00 48 89 df e8 8c 8a-04 00 49 ff c7 49 d1 ee ..H.......I..I.. |
| 372 | |
| 373 | Binary Images: |
| 374 | 0x7ffa2fc29000 - 0x7ffa2fdb7fff GLEngine (*) <7797ea1d-f2d0-3dc7-950b-961dbc8a0b73> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine |
| 375 | 0x1093b7000 - 0x115ceefff org.blenderfoundation.blender (3.1.0) <11ec9ab2-102c-3dcb-87e9-f3f15347e3e8> /Applications/Blender/Blender.app/Contents/MacOS/Blender |
| 376 | 0x12a540000 - 0x12a5abfff dyld (*) <cef5a27a-d50b-3020-af03-1734b19bc8c5> /usr/lib/dyld |
| 377 | 0x7ff817d0e000 - 0x7ff817d44fff libsystem_kernel.dylib (*) <5aa1e5be-b5b8-3a02-9885-a8c99e0ca378> /usr/lib/system/libsystem_kernel.dylib |
| 378 | 0x7ff817b92000 - 0x7ff817bd8fff libdispatch.dylib (*) <c8f7bfb6-4b1a-37cd-a32d-cd5069c916df> /usr/lib/system/libdispatch.dylib |
| 379 | 0x7ff817d45000 - 0x7ff817d50fff libsystem_pthread.dylib (*) <6c7561b4-4b92-3f45-921e-abe669299844> /usr/lib/system/libsystem_pthread.dylib |
| 380 | 0x7ff8207b4000 - 0x7ff8207d6fff com.apple.audio.caulk (1.0) <e76d1ab3-89c2-3a93-990b-30827fcf89b0> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk |
| 381 | 0x7ff81966a000 - 0x7ff819d91fff com.apple.audio.CoreAudio (5.0) <33f55d9c-eaef-3fbd-add5-ed3e54925762> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio |
| 382 | 0x123d42000 - 0x123d4ffff _socket.cpython-310-darwin.so (*) <099583aa-a77b-35dd-b414-f30dbc3a62c2> /Applications/Blender/Blender.app/Contents/Resources/3.1/python/lib/python3.10/lib-dynload/_socket.cpython-310-darwin.so |
| 383 | 0x7ff817d92000 - 0x7ff818294fff com.apple.CoreFoundation (6.9) <eab0e216-2a9e-31ce-9164-fdf3ebcf7bd3> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation |
| 384 | 0x7ff81a801000 - 0x7ff81b68ffff com.apple.AppKit (6.9) <d23b9681-3764-3298-a716-fbb511dd5a7c> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit |
| 385 | 0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ??? |
| 386 | |
| 387 | External Modification Summary: |
| 388 | Calls made by other processes targeting this process: |
| 389 | task_for_pid: 0 |
| 390 | thread_create: 0 |
| 391 | thread_set_state: 0 |
| 392 | Calls made by this process: |
| 393 | task_for_pid: 0 |
| 394 | thread_create: 0 |
| 395 | thread_set_state: 0 |
| 396 | Calls made by all processes on this machine: |
| 397 | task_for_pid: 0 |
| 398 | thread_create: 0 |
| 399 | thread_set_state: 0 |
| 400 | |
| 401 | VM Region Summary: |
| 402 | ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%) |
| 403 | Writable regions: Total=6.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.2G(100%) |
| 404 | |
| 405 | VIRTUAL REGION |
| 406 | REGION TYPE SIZE COUNT (non-coalesced) |
| 407 | =========== ======= ======= |
| 408 | Accelerate framework 384K 3 |
| 409 | Activity Tracing 256K 1 |
| 410 | CG backing stores 3840K 4 |
| 411 | CG image 696K 18 |
| 412 | ColorSync 224K 25 |
| 413 | CoreAnimation 144K 13 |
| 414 | CoreGraphics 12K 2 |
| 415 | CoreImage 4K 1 |
| 416 | CoreUI image data 1120K 9 |
| 417 | Foundation 16K 1 |
| 418 | Kernel Alloc Once 8K 1 |
| 419 | MALLOC 5.4G 3083 |
| 420 | MALLOC guard page 32K 8 |
| 421 | MALLOC_LARGE (reserved) 256K 1 reserved VM address space (unallocated) |
| 422 | MALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated) |
| 423 | OpenGL GLSL 256K 3 |
| 424 | STACK GUARD 132K 33 |
| 425 | Stack 102.8M 34 |
| 426 | Stack Guard 4K 1 |
| 427 | VM_ALLOCATE 396.9M 3940 |
| 428 | VM_ALLOCATE (reserved) 96.0M 1 reserved VM address space (unallocated) |
| 429 | __DATA 101.7M 422 |
| 430 | __DATA_CONST 17.5M 218 |
| 431 | __DATA_DIRTY 782K 122 |
| 432 | __FONT_DATA 4K 1 |
| 433 | __GLSLBUILTINS 5176K 1 |
| 434 | __LINKEDIT 708.7M 62 |
| 435 | __OBJC_RO 81.8M 1 |
| 436 | __OBJC_RW 3136K 2 |
| 437 | __TEXT 576.7M 431 |
| 438 | __UNICODE 588K 1 |
| 439 | dyld private memory 1152K 3 |
| 440 | mapped file 169.0M 30 |
| 441 | shared memory 784K 17 |
| 442 | =========== ======= ======= |
| 443 | TOTAL 7.8G 8494 |
| 444 | TOTAL, minus reserved VM space 7.5G 8494 |
| 445 | |
| 446 | |
| 447 | |
| 448 | ----------- |
| 449 | Full Report |
| 450 | ----------- |
| 451 | |
| 452 | {"app_name":"Blender","timestamp":"2022-02-03 22:04:38.00 +0100","app_version":"3.1.0","slice_uuid":"11ec9ab2-102c-3dcb-87e9-f3f15347e3e8","build_version":"3.1.0 2022-01-31","platform":1,"bundleID":"org.blenderfoundation.blender","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.1 (21C52)","incident_id":"2961041B-184F-4C27-81C0-EDB5DE529B51","name":"Blender"} |
| 453 | { |
| 454 | "uptime" : 37000, |
| 455 | "procLaunch" : "2022-02-03 21:50:59.4768 +0100", |
| 456 | "procRole" : "Foreground", |
| 457 | "version" : 2, |
| 458 | "userID" : 501, |
| 459 | "deployVersion" : 210, |
| 460 | "modelCode" : "Macmini8,1", |
| 461 | "procStartAbsTime" : 36805586127134, |
| 462 | "coalitionID" : 970, |
| 463 | "osVersion" : { |
| 464 | "train" : "macOS 12.1", |
| 465 | "build" : "21C52", |
| 466 | "releaseType" : "User" |
| 467 | }, |
| 468 | "captureTime" : "2022-02-03 22:04:35.9928 +0100", |
| 469 | "incident" : "2961041B-184F-4C27-81C0-EDB5DE529B51", |
| 470 | "bug_type" : "309", |
| 471 | "pid" : 2869, |
| 472 | "procExitAbsTime" : 37621928999013, |
| 473 | "cpuType" : "X86-64", |
| 474 | "procName" : "Blender", |
| 475 | "procPath" : "\/Applications\/Blender\/Blender.app\/Contents\/MacOS\/Blender", |
| 476 | "bundleInfo" : {"CFBundleShortVersionString":"3.1.0","CFBundleVersion":"3.1.0 2022-01-31","CFBundleIdentifier":"org.blenderfoundation.blender"}, |
| 477 | "storeInfo" : {"deviceIdentifierForVendor":"C36CE686-F8D3-5188-AA46-612C4C28F525","thirdParty":true}, |
| 478 | "parentProc" : "launchd", |
| 479 | "parentPid" : 1, |
| 480 | "coalitionName" : "org.blenderfoundation.blender", |
| 481 | "crashReporterKey" : "229ABBC2-C318-7915-FA97-7BBEFE9A75FB", |
| 482 | "bridgeVersion" : {"build":"19P647","train":"6.1"}, |
| 483 | "sip" : "enabled", |
| 484 | "externalGPUInfo" : "ID Vend\/Dev\n8938 687f1002\nSeconds Ago ID Type\n 37000.0 8938 Attach\n", |
| 485 | "vmRegionInfo" : "0xc8 is not in any region. Bytes before following region: 4449857336\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 1093b7000-115cef000 [201.2M] r-x\/r-x SM=COW ...MacOS\/Blender", |
| 486 | "isCorpse" : 1, |
| 487 | "exception" : {"codes":"0x0000000000000001, 0x00000000000000c8","rawCodes":[1,200],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x00000000000000c8"}, |
| 488 | "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":2869}, |
| 489 | "ktriageinfo" : "VM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\n", |
| 490 | "vmregioninfo" : "0xc8 is not in any region. Bytes before following region: 4449857336\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 1093b7000-115cef000 [201.2M] r-x\/r-x SM=COW ...MacOS\/Blender", |
| 491 | "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0}, |
| 492 | "faultingThread" : 0, |
| 493 | "threads" : [{"triggered":true,"id":208405,"instructionState":{"instructionStream":{"bytes":[0,133,255,127,10,72,255,198,72,57,241,117,223,235,31,128,136,160,26,0,0,16,128,139,255,5,0,0,48,199,131,188,174,0,0,0,0,0,0,128,139,7,6,0,0,16,76,139,179,136,141,0,0,77,133,246,15,132,132,0,0,0,69,49,255,65,188,1,0,0,0,65,246,198,1,116,109,73,107,199,88,72,139,132,3,8,97,0,0,72,139,136,56,2,0,0,139,137,200,0,0,0,43,139,44,182,0,0,133,201,126,74,72,141,112,40,15,182,139,161,198,0,0,133,201,116,31,65,15,68,204,72,193,225,3,72,141,12,73,49,210,128,140,16,156,0,0,0,8,72,131,194,24,72,57,209,117,239,199,131,188,174,0,0,0,0,0,0,129,139,12,6,0,0,0,32,2,0,72,137,223,232,140,138,4,0,73,255,199,73,209,238],"offset":96}},"threadState":{"r13":{"value":140552258772992},"rax":{"value":140546118579488},"rflags":{"value":66054},"cpu":{"value":2},"r14":{"value":1},"rsi":{"value":80},"r8":{"value":0},"cr2":{"value":200},"rdx":{"value":4294553238},"r10":{"value":2043},"r9":{"value":140552168155824},"r15":{"value":9},"rbx":{"value":140552258772992},"trap":{"value":14,"description":"(no mapping for user data read)"},"err":{"value":4},"r11":{"value":89233112},"rip":{"value":140712520805797,"matchesCrashFrame":1},"rbp":{"value":140701898928192},"rsp":{"value":140701898928160},"r12":{"value":1},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":4294964854}},"queue":"com.apple.main-thread","frames":[{"imageOffset":974245,"symbol":"gleUpdateCtxDirtyStateForBufStampChange","symbolLocation":340,"imageIndex":0},{"imageOffset":978209,"symbol":"gleBindBufferObject","symbolLocation":3249,"imageIndex":0},{"imageOffset":299275,"symbol":"glBindBuffer_Exec","symbolLocation":128,"imageIndex":0},{"imageOffset":145590390,"symbol":"blender::gpu::GLUniformBuf::update(void const*)","symbolLocation":118,"imageIndex":1},{"imageOffset":9139045,"symbol":"DRW_globals_update","symbolLocation":2629,"imageIndex":1},{"imageOffset":9158457,"symbol":"DRW_draw_render_loop_ex","symbolLocation":569,"imageIndex":1},{"imageOffset":20935562,"symbol":"view3d_main_region_draw","symbolLocation":138,"imageIndex":1},{"imageOffset":13342913,"symbol":"ED_region_do_draw","symbolLocation":337,"imageIndex":1},{"imageOffset":7603181,"symbol":"wm_draw_update","symbolLocation":1757,"imageIndex":1},{"imageOffset":7592224,"symbol":"WM_main","symbolLocation":48,"imageIndex":1},{"imageOffset":1560521,"symbol":"main","symbolLocation":873,"imageIndex":1},{"imageOffset":21758,"symbol":"start","symbolLocation":462,"imageIndex":2}]},{"id":208421,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208422,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208423,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208424,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208425,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208426,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208427,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208428,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208429,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208430,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208431,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208449,"name":"AMCP Logging Spool","frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":111040,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":6},{"imageOffset":8330,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":6},{"imageOffset":7502,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":6},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208474,"name":"com.apple.audio.IOThread.client","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":3311963,"symbol":"HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)","symbolLocation":111,"imageIndex":7},{"imageOffset":1798399,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":3937,"imageIndex":7},{"imageOffset":1792961,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":63,"imageIndex":7},{"imageOffset":3663724,"symbol":"HALB_IOThread::Entry(void*)","symbolLocation":72,"imageIndex":7},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208544,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208545,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208546,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208547,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208548,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208549,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208550,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208551,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208552,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208553,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208554,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208556,"frames":[{"imageOffset":29078,"symbol":"__accept","symbolLocation":10,"imageIndex":3},{"imageOffset":17288,"symbol":"sock_accept_impl","symbolLocation":24,"imageIndex":8},{"imageOffset":18402,"symbol":"sock_call_ex","symbolLocation":402,"imageIndex":8},{"imageOffset":8320,"symbol":"sock_accept","symbolLocation":144,"imageIndex":8},{"imageOffset":146444871,"symbol":"method_vectorcall_NOARGS","symbolLocation":135,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":146415807,"symbol":"method_vectorcall","symbolLocation":367,"imageIndex":1},{"imageOffset":148102566,"symbol":"thread_run","symbolLocation":70,"imageIndex":1},{"imageOffset":147776041,"symbol":"pythread_wrapper","symbolLocation":25,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208557,"frames":[{"imageOffset":36426,"symbol":"__select","symbolLocation":10,"imageIndex":3},{"imageOffset":148095756,"symbol":"time_sleep","symbolLocation":140,"imageIndex":1},{"imageOffset":146693765,"symbol":"cfunction_vectorcall_O","symbolLocation":277,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395962,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30538,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":146415807,"symbol":"method_vectorcall","symbolLocation":367,"imageIndex":1},{"imageOffset":148102566,"symbol":"thread_run","symbolLocation":70,"imageIndex":1},{"imageOffset":147776041,"symbol":"pythread_wrapper","symbolLocation":25,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208615,"name":"com.apple.NSEventThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":9},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":9},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":9},{"imageOffset":1756568,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":10},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208630,"frames":[{"imageOffset":36426,"symbol":"__select","symbolLocation":10,"imageIndex":3},{"imageOffset":148095756,"symbol":"time_sleep","symbolLocation":140,"imageIndex":1},{"imageOffset":146693765,"symbol":"cfunction_vectorcall_O","symbolLocation":277,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395962,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30538,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":146415807,"symbol":"method_vectorcall","symbolLocation":367,"imageIndex":1},{"imageOffset":148102566,"symbol":"thread_run","symbolLocation":70,"imageIndex":1},{"imageOffset":147776041,"symbol":"pythread_wrapper","symbolLocation":25,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":211851,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":211940,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":211990,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":212041,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]}], |
| 494 | "usedImages" : [ |
| 495 | { |
| 496 | "source" : "P", |
| 497 | "arch" : "x86_64", |
| 498 | "base" : 140712519831552, |
| 499 | "size" : 1634304, |
| 500 | "uuid" : "7797ea1d-f2d0-3dc7-950b-961dbc8a0b73", |
| 501 | "path" : "\/System\/Library\/Frameworks\/OpenGL.framework\/Versions\/A\/Resources\/GLEngine.bundle\/GLEngine", |
| 502 | "name" : "GLEngine" |
| 503 | }, |
| 504 | { |
| 505 | "source" : "P", |
| 506 | "arch" : "x86_64", |
| 507 | "base" : 4449857536, |
| 508 | "CFBundleShortVersionString" : "3.1.0", |
| 509 | "CFBundleIdentifier" : "org.blenderfoundation.blender", |
| 510 | "size" : 210993152, |
| 511 | "uuid" : "11ec9ab2-102c-3dcb-87e9-f3f15347e3e8", |
| 512 | "path" : "\/Applications\/Blender\/Blender.app\/Contents\/MacOS\/Blender", |
| 513 | "name" : "Blender", |
| 514 | "CFBundleVersion" : "3.1.0 2022-01-31" |
| 515 | }, |
| 516 | { |
| 517 | "source" : "P", |
| 518 | "arch" : "x86_64", |
| 519 | "base" : 5005115392, |
| 520 | "size" : 442368, |
| 521 | "uuid" : "cef5a27a-d50b-3020-af03-1734b19bc8c5", |
| 522 | "path" : "\/usr\/lib\/dyld", |
| 523 | "name" : "dyld" |
| 524 | }, |
| 525 | { |
| 526 | "source" : "P", |
| 527 | "arch" : "x86_64", |
| 528 | "base" : 140703528181760, |
| 529 | "size" : 225280, |
| 530 | "uuid" : "5aa1e5be-b5b8-3a02-9885-a8c99e0ca378", |
| 531 | "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib", |
| 532 | "name" : "libsystem_kernel.dylib" |
| 533 | }, |
| 534 | { |
| 535 | "source" : "P", |
| 536 | "arch" : "x86_64", |
| 537 | "base" : 140703526625280, |
| 538 | "size" : 290816, |
| 539 | "uuid" : "c8f7bfb6-4b1a-37cd-a32d-cd5069c916df", |
| 540 | "path" : "\/usr\/lib\/system\/libdispatch.dylib", |
| 541 | "name" : "libdispatch.dylib" |
| 542 | }, |
| 543 | { |
| 544 | "source" : "P", |
| 545 | "arch" : "x86_64", |
| 546 | "base" : 140703528407040, |
| 547 | "size" : 49152, |
| 548 | "uuid" : "6c7561b4-4b92-3f45-921e-abe669299844", |
| 549 | "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib", |
| 550 | "name" : "libsystem_pthread.dylib" |
| 551 | }, |
| 552 | { |
| 553 | "source" : "P", |
| 554 | "arch" : "x86_64", |
| 555 | "base" : 140703673565184, |
| 556 | "CFBundleShortVersionString" : "1.0", |
| 557 | "CFBundleIdentifier" : "com.apple.audio.caulk", |
| 558 | "size" : 143360, |
| 559 | "uuid" : "e76d1ab3-89c2-3a93-990b-30827fcf89b0", |
| 560 | "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk", |
| 561 | "name" : "caulk" |
| 562 | }, |
| 563 | { |
| 564 | "source" : "P", |
| 565 | "arch" : "x86_64", |
| 566 | "base" : 140703554772992, |
| 567 | "CFBundleShortVersionString" : "5.0", |
| 568 | "CFBundleIdentifier" : "com.apple.audio.CoreAudio", |
| 569 | "size" : 7503872, |
| 570 | "uuid" : "33f55d9c-eaef-3fbd-add5-ed3e54925762", |
| 571 | "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio", |
| 572 | "name" : "CoreAudio", |
| 573 | "CFBundleVersion" : "5.0" |
| 574 | }, |
| 575 | { |
| 576 | "source" : "P", |
| 577 | "arch" : "x86_64", |
| 578 | "base" : 4896071680, |
| 579 | "size" : 57344, |
| 580 | "uuid" : "099583aa-a77b-35dd-b414-f30dbc3a62c2", |
| 581 | "path" : "\/Applications\/Blender\/Blender.app\/Contents\/Resources\/3.1\/python\/lib\/python3.10\/lib-dynload\/_socket.cpython-310-darwin.so", |
| 582 | "name" : "_socket.cpython-310-darwin.so" |
| 583 | }, |
| 584 | { |
| 585 | "source" : "P", |
| 586 | "arch" : "x86_64h", |
| 587 | "base" : 140703528722432, |
| 588 | "CFBundleShortVersionString" : "6.9", |
| 589 | "CFBundleIdentifier" : "com.apple.CoreFoundation", |
| 590 | "size" : 5255168, |
| 591 | "uuid" : "eab0e216-2a9e-31ce-9164-fdf3ebcf7bd3", |
| 592 | "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation", |
| 593 | "name" : "CoreFoundation", |
| 594 | "CFBundleVersion" : "1856.105" |
| 595 | }, |
| 596 | { |
| 597 | "source" : "P", |
| 598 | "arch" : "x86_64", |
| 599 | "base" : 140703573217280, |
| 600 | "CFBundleShortVersionString" : "6.9", |
| 601 | "CFBundleIdentifier" : "com.apple.AppKit", |
| 602 | "size" : 15265792, |
| 603 | "uuid" : "d23b9681-3764-3298-a716-fbb511dd5a7c", |
| 604 | "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit", |
| 605 | "name" : "AppKit", |
| 606 | "CFBundleVersion" : "2113.20.111" |
| 607 | }, |
| 608 | { |
| 609 | "size" : 0, |
| 610 | "source" : "A", |
| 611 | "base" : 0, |
| 612 | "uuid" : "00000000-0000-0000-0000-000000000000" |
| 613 | } |
| 614 | ], |
| 615 | "sharedCache" : { |
| 616 | "base" : 140703525179392, |
| 617 | "size" : 15216738304, |
| 618 | "uuid" : "40432a03-88d3-305f-9c0c-e7549e71d927" |
| 619 | }, |
| 620 | "vmSummary" : "ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)\nWritable regions: Total=6.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.2G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 384K 3 \nActivity Tracing 256K 1 \nCG backing stores 3840K 4 \nCG image 696K 18 \nColorSync 224K 25 \nCoreAnimation 144K 13 \nCoreGraphics 12K 2 \nCoreImage 4K 1 \nCoreUI image data 1120K 9 \nFoundation 16K 1 \nKernel Alloc Once 8K 1 \nMALLOC 5.4G 3083 \nMALLOC guard page 32K 8 \nMALLOC_LARGE (reserved) 256K 1 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated)\nOpenGL GLSL 256K 3 \nSTACK GUARD 132K 33 \nStack 102.8M 34 \nStack Guard 4K 1 \nVM_ALLOCATE 396.9M 3940 \nVM_ALLOCATE (reserved) 96.0M 1 reserved VM address space (unallocated)\n__DATA 101.7M 422 \n__DATA_CONST 17.5M 218 \n__DATA_DIRTY 782K 122 \n__FONT_DATA 4K 1 \n__GLSLBUILTINS 5176K 1 \n__LINKEDIT 708.7M 62 \n__OBJC_RO 81.8M 1 \n__OBJC_RW 3136K 2 \n__TEXT 576.7M 431 \n__UNICODE 588K 1 \ndyld private memory 1152K 3 \nmapped file 169.0M 30 \nshared memory 784K 17 \n=========== ======= ======= \nTOTAL 7.8G 8494 \nTOTAL, minus reserved VM space 7.5G 8494 \n", |
| 621 | "legacyInfo" : { |
| 622 | "threadTriggered" : { |
| 623 | "queue" : "com.apple.main-thread" |
| 624 | } |
| 625 | }, |
| 626 | "trialInfo" : { |
| 627 | "rollouts" : [ |
| 628 | { |
| 629 | "rolloutId" : "60da5e84ab0ca017dace9abf", |
| 630 | "factorPackIds" : { |
| 631 | |
| 632 | }, |
| 633 | "deploymentId" : 240000008 |
| 634 | }, |
| 635 | { |
| 636 | "rolloutId" : "607844aa04477260f58a8077", |
| 637 | "factorPackIds" : { |
| 638 | "SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a" |
| 639 | }, |
| 640 | "deploymentId" : 240000066 |
| 641 | }, |
| 642 | { |
| 643 | "rolloutId" : "601d9415f79519000ccd4b69", |
| 644 | "factorPackIds" : { |
| 645 | "SIRI_TEXT_TO_SPEECH" : "61f040507303d250981c88d9" |
| 646 | }, |
| 647 | "deploymentId" : 240000377 |
| 648 | }, |
| 649 | { |
| 650 | "rolloutId" : "5fc94383418129005b4e9ae0", |
| 651 | "factorPackIds" : { |
| 652 | |
| 653 | }, |
| 654 | "deploymentId" : 240000225 |
| 655 | }, |
| 656 | { |
| 657 | "rolloutId" : "602ad4dac86151000cf27e46", |
| 658 | "factorPackIds" : { |
| 659 | "SIRI_DICTATION_ASSETS" : "6193d03f2171a2330e561dfc" |
| 660 | }, |
| 661 | "deploymentId" : 240000298 |
| 662 | }, |
| 663 | { |
| 664 | "rolloutId" : "5ffde50ce2aacd000d47a95f", |
| 665 | "factorPackIds" : { |
| 666 | |
| 667 | }, |
| 668 | "deploymentId" : 240000102 |
| 669 | } |
| 670 | ], |
| 671 | "experiments" : [ |
| 672 | { |
| 673 | "treatmentId" : "c4ac6461-f0e0-47b0-a630-f7739342ca3b", |
| 674 | "experimentId" : "60c785f07aa5af21f0101872", |
| 675 | "deploymentId" : 400000012 |
| 676 | } |
| 677 | ] |
| 678 | } |
| 679 | } |
| 680 | |
| 681 | Model: Macmini8,1, BootROM 1715.60.5.0.0 (iBridge: 19.16.10647.0.0,0), 6 processors, 6-Core Intel Core i7, 3,2 GHz, 8 GB, SMC |
| 682 | Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In |
| 683 | Graphics: AMD Radeon RX Vega 56, AMD Radeon RX Vega 56, PCIe, 8 GB |
| 684 | Display: BenQ EL2870U, 5120 x 2880 (5K/UHD+ - Ultra High Definition Plus), Main, MirrorOff, Online |
| 685 | Memory Module: BANK 0/ChannelA-DIMM0, 4 GB, DDR4, 2667 MHz, Micron, 4ATF51264HZ-2G6E3 |
| 686 | Memory Module: BANK 2/ChannelB-DIMM0, 4 GB, DDR4, 2667 MHz, Micron, 4ATF51264HZ-2G6E3 |
| 687 | AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 19:26:30 version 9.30.464.0.32.5.76 FWID 01-45ccefcd |
| 688 | Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports |
| 689 | Network Service: Wi-Fi, AirPort, en1 |
| 690 | PCI Card: AMD Radeon RX Vega 56, Display Controller, Thunderbolt@198,0,0 |
| 691 | PCI Card: pci1002,aaf8, Audio Device, Thunderbolt@198,0,1 |
| 692 | USB Device: Portable SSD T5 |
| 693 | USB Device: USB31Bus |
| 694 | USB Device: USB3.1 Hub |
| 695 | USB Device: USB Storage |
| 696 | USB Device: USB2.1 Hub |
| 697 | USB Device: Gaming_Mouse |
| 698 | USB Device: USB DEVICE |
| 699 | USB Device: Portable SSD T5 |
| 700 | USB Device: T2Bus |
| 701 | USB Device: Headset |
| 702 | USB Device: Apple T2 Controller |
| 703 | Thunderbolt Bus: Mac mini, Apple Inc., 47.5 |
| 704 | Thunderbolt Bus: Mac mini, Apple Inc., 47.5 |
| 705 | Thunderbolt Device: Core X, Razer, 1, 33.1 |
