Maniphest T95693
No updates when changing the texture mapping of texture nodes
Closed, Duplicate
None
jay steven (jaysteven)
Feb 11 2022, 5:06 AM
  • BF Blender
  • Render & Cycles
  • EEVEE & Viewport
Omar Emara (OmarSquircleArt)
Changing the texture mapping of a texture node will not rerender or update the scene, either on Cycles or the viewport.
This used to work on 3.0, but stopped working in 3.1.
Original Report
Operating system: Windows-10-10.0.18363-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 980 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.27
Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-02-06 00:25, hash: rB48fbf0baea88
Addon Information
Name: Sun Position (3, 1, 2)
Author: Michael Martin
[Rotation of the HDRI is not updating with the rotation given under the Sun Position drop down in world properties. It does change to the new position if you mess around with other settings, prompting it to update]
[HDRI in an environment texture. Sync sun to texture.]
jay steven (jaysteven) created this task.Feb 11 2022, 5:06 AM
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Confirmed.Mar 23 2022, 12:36 PM
Omar Emara (OmarSquircleArt) edited projects, added BF Blender, Render & Cycles, EEVEE & Viewport; removed Add-ons (Community).
Omar Emara (OmarSquircleArt) added a subscriber: Omar Emara (OmarSquircleArt).
This doesn't seem related to the add-on itself. Apparently, the render engine doesn't receive updates about changes to texture mappings of texture nodes. This works in 3.0, so it is a 3.1 regression.
Omar Emara (OmarSquircleArt) renamed this task from HDRI rotation not updating when given a new rotation in drop down menu. Sync Sun to Texture. to No updates when changing the texture mapping of texture nodes.Mar 23 2022, 12:41 PM
Omar Emara (OmarSquircleArt) updated the task description.
