Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.65
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Worked: (Blender 2.93)
The issue seems that the Attribute node set to object, with the attribute "scale" doesn't update in realtime on GPU. For example, using this node, vector math multiplied with a vector node set to object, locks the texture scale in place, so that when you scale objects, you always have the same scale texture (with more tiling). This is useful for making procedural materials.
The issue is that this doesn't work when on optix or cuda, but when using cpu it works as intended.
Open the attached blender and scale the mesh with the render source set to CPU, you will see the texture has locked scale. Set it to gpu and you will see that it does not.
The node tree setup is in the left side of the window and it's just a texture coordinate node set to object, vector math multiplied with an attribute node set to object with the 'scale' attribute.
