Operating system: Windows 10 Home, Build 19044.1526
Graphics card: Intel(R) UHD Graphics 620
Broken: 3.20 Alpha, 8ddeb71a5513, master, 2022-02-25
Worked: 3.01
Caused by rB74611e355568: Fix T93331: Gizmo tool options reset when switching tools
Changing tool options for some tools like Mesh Bevel, Loop Cut, Curve point randomize, etc. has no effect. However, changing them from properties works.
I suspect that it has something to do with using tool.operator_properties for draw_settings in space_toolsystem_toolbar.py, but that's just a guess.
- Select Startup Cube
- Go to Edit Mode
- Select Loop Cut tool
- Increment the Number of Cuts from the tool header at the top (or the tool settings on the right)
- Make a cut on the cube
- Only one cut will be created, regardless of the number of cuts specified.
