Maniphest T96061
UV tangents not seamless
Closed, Duplicate
None
tempdevnova (tempdevnova)
Feb 27 2022, 4:58 PM
  • BF Blender
Germano Cavalcante (mano-wii)
Pratik Borhade (PratikPB2123)
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.07
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
When using a UV map with the tangent node the resulting tangent sometimes isn't seamless although it should be.
Test file:
When looking at the mesh and UV map it is apparent that the resulting tangents should look like that of the tangent node when set to radial Z, but it doesn't.
Thank you and have a great day.
Related Objects
tempdevnova (tempdevnova) created this task.Feb 27 2022, 4:58 PM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Feb 28 2022, 7:23 AM
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).Mar 1 2022, 7:16 PM
I'm pretty sure this is a result of the problem described in T80253: Cylinder smooth shading issue.
Basically, the problem is a limitation of the geometries that work with triangles.
The UVs interpolation is done on the triangles and not uniformly on the polygon.
You can better understand the problem with this image:
This is something the developers are aware of and unfortunately has no simple fix.
You can edit the geometry to work around the problem.
Germano Cavalcante (mano-wii) closed this task as a duplicate of T80253: Cylinder smooth shading issue.Mar 1 2022, 7:16 PM
tempdevnova (tempdevnova) added a comment.Mar 2 2022, 4:24 PM
Im pretty sure that is not the case, because in the case of tangents it doesn't matter whether the mesh is triangulated or not.
