Maniphest T96155
Blender not redering
Closed, Archived
None
Rodrigo Miguel Vicente Figueiredo (wavy_off30)
Mar 3 2022, 7:10 PM
  • BF Blender
Ethan Hall (Ethan1080)
Pratik Borhade (PratikPB2123)
Richard Antalik (ISS)
https://pangoly.com/en/build/share/2022/1/27/custom/a947dcb3-429c-40c6-b19a-8554efe665f1
latest one
when i try to render a animacion nothing happens, i left it running for 10h and nothing, tried redering a simple cube and it worked fine, its jst with the file im workng that it appears nothing, but when i try to render a frame it workes fine too
render animacion
Related Objects
Duplicates Merged Here
T96143: Rendering problem
Rodrigo Miguel Vicente Figueiredo (wavy_off30) created this task.Mar 3 2022, 7:10 PM
Ethan Hall (Ethan1080) added a subscriber: Ethan Hall (Ethan1080).EditedMar 3 2022, 8:30 PM
Is D:\gamemax\Downloads\ a valid location on your drive?
I set the output path to C:\tmp\asd and was able to render the animation with Blender 3.0.1.
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).Mar 4 2022, 2:06 AM
That could be an issue here. I would expect error though if I provided invalid path so that could be valid bug too.
@Rodrigo Miguel Vicente Figueiredo (wavy_off30) Please check if output path is valid
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Mar 4 2022, 2:06 AM
Rodrigo Miguel Vicente Figueiredo (wavy_off30) added a comment.EditedMar 4 2022, 2:45 AM
IT WORKED THANK YOU GUYS
LY SO MUCH
Richard Antalik (ISS) closed this task as Archived.Mar 4 2022, 3:34 AM
Actually there is error message produced, but it's visible only in main window, so will close this report. Even if this could be improved, it's not a bug in Blender.
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
Pratik Borhade (PratikPB2123) merged a task: T96143: Rendering problem.Mar 4 2022, 7:25 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
