Maniphest T96192
Vetice group assignments scrambled
Closed, Duplicate
None
mark (emwardicus)
Mar 6 2022, 12:11 PM
  • BF Blender
Ethan Hall (Ethan1080)
mark (emwardicus)
Operating system: Windows-10-10.0.17763-SP0 64 Bits
Graphics card: AMD Radeon(TM) R4 Graphics ATI Technologies Inc. 4.5.13547 Core Profile Context 25.20.15018.12
Broken: version: 2.93.5, branch: master, commit date: 2021-10-05 12:04, hash: rBa791bdabd0b2
was attempting to delete a shapekey, accidentally deleted a vertice group instead. I press CTRL+Z, this does not undo the deletion of a vertice group, why why does this not undo the deletion of a vertice group? i dont even know which one is now missing. i cannot close the file to recover because i lose 3 hours of work, only option is to rejoin the mesh to the armature. select both mesh and bones CTRL+P empty groups, vertice groups are recovered.... The vertice assignments are shuffled...WHY ARE THE VERTICE ASSIGNMENTS NOW SHUFFLED?????????? teeth are attached to toe bones, legs are attached to finger bones, there are fucking wings attached to the face, WHY ???? WHY???? WHO ALLOWED THIS TO HAPPEN?????? WHO DECIDED TO CHANGE THE VERTICES?????? I JUST WANTED TO RECOVER A VERTICE GROUP! CHAOS HAS CONSUMED THEE! ALL IS HELL! AUTOSAVE WAS 4 HOURS AGO, STATISTICS NUMBERS ARE OFF, CANNOT TRANSFER SHAPEKEYS FROM OLD FILE SUCCESSFULLY. I NOW HAVE TO DELETE ALL VERTICE GROUPS AND REASSIGN OVER 5000 VERTICES TO ARMATURE ALL OVER AGAIN. BECAUSE THE CTRL+Z DOESNT RECOVER DELETED VERTICE GROUPS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1 create mesh
2 create bones
3 attach vertices to bones
4 delete vertice group
5 CTRL+Z
6 watch as nothing happens
7 cry in the corner for your god has abandoned you
mark (emwardicus) created this task.Mar 6 2022, 12:11 PM
Ethan Hall (Ethan1080) changed the task status from Needs Triage to Confirmed.Mar 6 2022, 9:54 PM
Ethan Hall (Ethan1080) added a subscriber: Ethan Hall (Ethan1080).
Thank you for your report. I can confirm this. This problem appears to arise from allowing vertex groups to be deleted in edit mode. The undo for the delete vertex groups is done first, before any edit mode changes are undone, and does not properly account for edit mode changes. If I continued to undo the edit mode changes past the point of where I deleted the vertex group, I was able to recover the correct vertex groups.
Here is a demonstration:
Here is a test file:
Ethan Hall (Ethan1080) added a comment.Mar 6 2022, 9:58 PM
This report is likely a duplicate of: https://developer.blender.org/T71980
Pratik Borhade (PratikPB2123) closed this task as a duplicate of T71980: Undo unavailable for Remove Vertex Group in edit mode.Mar 7 2022, 6:06 AM
