Operating system: Windows 10
Graphics card: AMD Ryzen 7, 2700, 8-core
Blender Version: 3.0.1
Can't render particle types: Halo, Lines, Path.
- Add object.
- Add a material to an object in the materials tab
- Open the Render Properties tab and change the engine to Cycles.
- Add a particle system to it from the Particle Properties tab.
- Open the Render tab in Particle Properties.
- Choose one of the particle types: Halo, Lines or Path.
- Make sure the particles have the same material as the object (Particle Properties > Render > Material).
- Run the animation for several frames to see the particles in the viewport.
- Start rendering.
Bottom line: only the object is visible, but no particles.
