Windows 10
GTS 450
3.1.0 c77597cd0e15
Texture baking not working.
When I try to bake a texture in this version, I am immediately given an empty transparent image.
In version 3.0.1, everything works fine.
Gif:
| Denis (iKotyaX) | |
| Mar 10 2022, 3:04 PM |
| Denis (iKotyaX) |
| Pratik Borhade (PratikPB2123) |
Windows 10
GTS 450
3.1.0 c77597cd0e15
Gif:
Hello,I'm just trying to bake the texture,
Here are the steps I follow:
2.Color change
3.Adding an empty texture to node editor (1024x1024)
(Even if you change any parameters, for example, bake only the color, the image will still be transparent)
Hi, I still can not reproduce. Can you test again on latest 3.2 build?: https://builder.blender.org/download/daily/
Also, any luck with factory prefs?: Edit → Preferences → Save & Load (3 horizontal lines) → Load Factory preferences
@Denis (iKotyaX) hi, have you tried replicating the issue on 3.2 build?: https://builder.blender.org/download/daily
Do you see the exact same issue when you bake image texture in the file I had uploaded?
