Maniphest T96324
Regression: Resizing an image is not correctly reflected in the image editor until the UI is updated
Closed, Resolved
Jeroen Bakker (jbakker)
Alaska (Alaska)
Mar 11 2022, 7:15 AM
  • BF Blender
  • EEVEE & Viewport
Alaska (Alaska)
Francois (FRworld)
Pratik Borhade (PratikPB2123)
Operating system: Linux-5.16.0-3-amd64-x86_64-with-glibc2.33 64 Bits
Graphics card: NVIDIA GeForce RTX 3060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 510.54
Broken version: 3.2.0 Alpha, branch: master, commit date: 2022-03-11 04:29, hash: rBf6564df3515f
Broken version: 3.1 Release
Worked: All versions prior to commit rB5e9c1feb8aff: Image Engine: Performance 8 byte images.
Resizing an image in the image editor will not update correct. A correct update will occur once the UI is changed. This may be related to T96312: Regression: Image Editor Flip option isn't working and T96323: Regression: Invert colour is not reflected in the image viewer until a UI change
Here is a video demonstrating the issue:
  1. Load an image in the image editor.
  2. Select from the top ImageResize and change the size of the image.
  3. Notice how the image has not been properly updated. Split the editor and the image will update to the correct result.
Revisions and Commits
rB Blender
Related Objects
Mentioned In
T96241: 3.1: Potential candidates for corrective releases
P2839 3.1 R
T96355: Image editor commands not working properly - Gives glitchy results
Mentioned Here
T96163: Regression: Image editor fails to update after undoing stroke
rBeb0f8317e231: Cleanup: ED_view3d_win_to_delta & ED_view3d_calc_zfac usage
rBeabdcdcd44b9: Merge remote-tracking branch 'origin/blender-v3.1-release'
rB507a4deef149: Fix invalid creation of partial image updater
Alaska (Alaska) created this task.Mar 11 2022, 7:15 AM
Alaska (Alaska) added a subscriber: Jeroen Bakker (jbakker).
CC @Jeroen Bakker (jbakker) as you worked on a fix for a similar issue.
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Mar 11 2022, 8:06 AM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Mar 11 2022, 8:10 AM
Pratik Borhade (PratikPB2123) triaged this task as High priority.
Pratik Borhade (PratikPB2123) added a project: EEVEE & Viewport.
Worked: Presumably prior to rB507a4deef149
Not this time :)
This is actually broke between eb0f8317e231 - eabdcdcd44b9
Alaska (Alaska) added a comment.EditedMar 11 2022, 10:21 AM
You're right, it is caused by rB5e9c1feb8aff: Image Engine: Performance 8 byte images. instead
Alaska (Alaska) updated the task description.Mar 11 2022, 10:21 AM
Francois (FRworld) added a subscriber: Francois (FRworld).Mar 12 2022, 7:11 AM
Pratik Borhade (PratikPB2123) added a comment.Mar 19 2022, 12:13 PM
Following change fixes the issue for me. This is same as the fix of T96163
diff --git a/source/blender/editors/space_image/image_ops.c b/source/blender/editors/space_image/image_ops.c
index 3721ea81c04..b48ec4be24c 100644
--- a/source/blender/editors/space_image/image_ops.c
+++ b/source/blender/editors/space_image/image_ops.c
@@ -2992,7 +2992,7 @@ static int image_scale_exec(bContext *C, wmOperator *op)
   ED_image_undo_push_end();
   /* Force GPU re-upload, all image is invalid. */
-  BKE_image_free_gputextures(ima);
+  BKE_image_partial_update_mark_full_update(ima);
   DEG_id_tag_update(&ima->id, 0);
   WM_event_add_notifier(C, NC_IMAGE | NA_EDITED, ima);
Pratik Borhade (PratikPB2123) mentioned this in P2839 3.1 R.Mar 20 2022, 12:20 PM
Philipp Oeser (lichtwerk) renamed this task from Resizing an image is not correctly reflected in the image editor until the UI is updated to Regression: Resizing an image is not correctly reflected in the image editor until the UI is updated.Mar 22 2022, 4:06 PM
Dalai Felinto (dfelinto) assigned this task to Jeroen Bakker (jbakker).Mar 25 2022, 4:10 PM
Jeroen Bakker (jbakker) closed this task as Resolved by committing rB2fc77071b51a: Image editor: not updating after image operation..Mar 25 2022, 4:38 PM
Jeroen Bakker (jbakker) added a commit: rB2fc77071b51a: Image editor: not updating after image operation..
Philipp Oeser (lichtwerk) added a commit: rBf6e2c9bc97d2: Image editor: not updating after image operation..Mar 28 2022, 4:27 PM
