Maniphest T96337
Export Wavefront OBJ incorrect
Closed, Archived
None
Domenico (Realgigabyte)
Mar 11 2022, 3:17 PM
  • Add-ons (Community)
Germano Cavalcante (mano-wii)
Thomas Dinges (dingto)
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: Intel(R) HD Graphics 530 Intel 4.5.0 - Build 27.20.100.8682
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash: rBc77597cd0e15
Addon Information
Name: Wavefront OBJ format (3, 9, 0)
Author: Campbell Barton, Bastien Montagne
When exporting to OBJ some meshes have extra faces where is meant to be void.
Please see attached blender file
The arch is obtained from a cube with a cylinder (boolean)
You can see that the OBJ rendering still has extra faces covering the arch. This is not how it appears in the viewport.
Domenico (Realgigabyte) renamed this task from Export Wavefront OBJ incorret to Export Wavefront OBJ incorrect.Mar 11 2022, 3:17 PM
Domenico (Realgigabyte) created this task.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Mar 11 2022, 3:32 PM
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).
I can't see these "extra faces" by importing the attached .obj file.
Could you provide an image showing the problem?
Thomas Dinges (dingto) added a subscriber: Thomas Dinges (dingto).Mar 11 2022, 3:53 PM
Are you using the new OBJ Exporter or the old python add-on? (The new one is just called Wavefront OBJ, the old one has "Old" in its name)
Domenico (Realgigabyte) added a comment.Mar 11 2022, 3:59 PM
I am not in my pc now but can try to open with the Windows 3D Viewer i can see the problem there (and when I try to import to other applications)
Domenico (Realgigabyte) added a comment.Mar 11 2022, 9:01 PM
This how it looks when opened on other apps:
Domenico (Realgigabyte) added a comment.EditedMar 15 2022, 10:35 AM
Hi, I just would like to add that the problem with 3rd party compatibility is resolved if "Triangulated Mesh" option is selected in the export dialog.
Selecting this option all meshes are visualized correctly.
Germano Cavalcante (mano-wii) closed this task as Archived.Mar 15 2022, 1:10 PM
The problem is not in Blender then.
Blender exports as a polygon. The software that has to triangulate it.
I suggest you report the problem in the bug tracker of the app with the issue.
Thanks for the report anyway.
