Maniphest T96355
Image editor commands not working properly - Gives glitchy results
Closed, Archived
None
Francois (FRworld)
Mar 11 2022, 11:06 PM
  • BF Blender
Alaska (Alaska)
Francois (FRworld)
Operating system: macOS-12.2-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Apple 4.1 Metal - 76.3
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash: rBc77597cd0e15
The image editor commands (Invert, Resize, Flip) are not working properly.
  • Create a new blender document
  • Change the 3D viewport to "image editor"
  • Change editing context to "Paint"
  • Go to the image menu -> New -> leave to defaults settings and click OK
  • Draw a random stroke with the default white brush to have something on screen
  • Go to Image menu -> Select any command like Invert red channel, Flip Horizontally, or resize to 512x512
  • NOTHING HAPPENS
  • But if you click on the image to add another paint stroke, some areas of the image will finally update with glitchy artifacts.
Francois (FRworld) created this task.Mar 11 2022, 11:06 PM
Alaska (Alaska) closed this task as Archived.Mar 12 2022, 2:26 AM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
These issues have been reported in T96323: Regression: Invert colour is not reflected in the image viewer until a UI change T96324: Regression: Resizing an image is not correctly reflected in the image editor until the UI is updated T96312: Regression: Image Editor Flip option isn't working
The fixes for those reports will most likely fix the issue with the "glitchy artifacts" you talk about in your report. As such I will archive this report as there are already reports for this issue.
