Maniphest T96551
UI refresh issue: sometimes, no keyframes appear in dopesheet until I resize the window
Closed, Archived
None
tobiasBora (tobiasBora)
Mar 17 2022, 10:45 AM
  • BF Blender
Pratik Borhade (PratikPB2123)
Operating system: NixOs
Graphics card: Intel Corporation WhiskeyLake-U GT2 [UHD Graphics 620] (rev 02)
Broken: 3.1
Sometimes, the UI in the dope sheet does not refresh until I resize it. It often occurs if I've nothing selected, and then select an object with some animations (loc/rot/scale): no keyframes are visible (click to play the animation):
I can't really find any deterministic way to obtain this behavior, it just occurs from time to time on my projects. But in theory, just add an animation to some objects. Select/deselect the object: at some points your view in the dopesheet should not show the keyframes.
tobiasBora (tobiasBora) created this task.Mar 17 2022, 10:45 AM
tobiasBora (tobiasBora) updated the task description.
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Mar 17 2022, 12:01 PM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Mar 17 2022, 12:39 PM
Hi, thanks for the report. Can not reproduce actually.
You have this issue with a particular file or you can reproduce it from scratch? (keyframes to default cube)
Any luck with factory preferences?: EditPreferencesSave & Load (3 horizontal lines)Load Factory preferences
Pratik Borhade (PratikPB2123) closed this task as Archived.Mar 31 2022, 7:40 AM
tobiasBora (tobiasBora) added a comment.Mar 31 2022, 12:26 PM
Thanks for your answer, and sorry for the time I spent to answer, I was quite busy these days. I was able to reproduce it with different files, but this problems occurs quite rarely so it's hard to provide precise steps to reach this issue... After playing with the cube for 2mn, I was not able to reproduce it, but it does not mean that it is not reproducible using the simple cube file. When I got the above errors, I was spending several hours on the same file.
Pratik Borhade (PratikPB2123) reopened this task as Needs Information from User.Apr 1 2022, 5:10 AM
Hi, thanks for getting back. To fix the problem, we need to be able to replicate it first.
Can you upload the file where problem occurs?
I'm not sure if you've tried factory reset. Can you check? EditPreferencesSave & Load (3 horizontal lines)Load Factory preferences
Pratik Borhade (PratikPB2123) added a comment.Apr 14 2022, 6:27 AM
Hi, any news?
Pratik Borhade (PratikPB2123) closed this task as Archived.EditedMay 11 2022, 7:46 PM
Please test again in latest beta build: https://builder.blender.org/download/daily/
