Maniphest T96553
Selecting vertices when Subdivision on cage is activated crashes blender
Closed, Archived
None
Hugo (Chug)
Mar 17 2022, 11:09 AM
  • BF Blender
Hugo (Chug)
Kévin Dietrich (kevindietrich)
Pratik Borhade (PratikPB2123)
Thomas Dinges (dingto)
Operating system: Win10
Graphics card: RTX 3090
Broken: 3.1 master
When you activate the "on cage option" of the subdivide modifier then proceed to select vertices Blender crashes (only when GPU subdiv is turned on)
Temporary fix
Turn off GPU subdivs
Hugo (Chug) created this task.Mar 17 2022, 11:09 AM
Thomas Dinges (dingto) changed the task status from Needs Triage to Needs Information from User.Mar 17 2022, 11:54 AM
Thomas Dinges (dingto) added a subscriber: Thomas Dinges (dingto).
Cannot confirm a crash, neither with 3.1 nor with latest master. Is it happening with the default cube on your system? Otherwise please upload a example file.
Also make sure you have the latest GPU driver installed.
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Mar 17 2022, 12:07 PM
Kévin Dietrich (kevindietrich) closed this task as Archived.Mar 29 2022, 1:08 PM
Kévin Dietrich (kevindietrich) added a subscriber: Kévin Dietrich (kevindietrich).
