Maniphest T96591
Gizmos became significantly harder to use
Closed, Resolved
None
Ilya Zmetnyy (Led_Astray)
Mar 18 2022, 9:27 AM
  • BF Blender
Pratik Borhade (PratikPB2123)
Operating system: Fedora 35 Xfce Spin
Graphics card: NVIDIA GeForce GTX 750 Ti
Broken: 3.1
Worked: 2.93
Gizmos that have a circle around them are significantly harder to grab, probably pixel perfect and don't work from all angles
  1. Switch to Extrude or Scale tool
  2. Try to use the gizmo on of the axis
Here's the video. On 2.93 it works perfectly fine from any angle and distance
Ilya Zmetnyy (Led_Astray) created this task.Mar 18 2022, 9:27 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).EditedMar 18 2022, 9:50 AM
Hi, thanks for the report. Looks similar as reported in T96435: Regression: very long input delay when dragging some gizmos handles in macOS
Can you confirm?
My bad, other report is not related with this. T96435 is reported on master (3.2)
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Mar 18 2022, 9:51 AM
Ilya Zmetnyy (Led_Astray) added a comment.Mar 18 2022, 9:55 AM
Thanks Pratik, but my issue is not the same. In the video I don't actually try to use them, I'm just trying to find the angle and position where they would highlight. And as you can see, from many angles the axis doesn't highlight (stays dark), if I use the gizmo in this case it will scale or extrude in all directions at once
Ilya Zmetnyy (Led_Astray) changed the task status from Needs Information from User to Needs Triage.Mar 18 2022, 9:56 AM
Pratik Borhade (PratikPB2123) added a comment.Mar 18 2022, 10:05 AM
Same problem with factory preferences?: EditPreferencesSave & Load (3 horizontal lines)Load Factory preferences
Ilya Zmetnyy (Led_Astray) added a comment.Mar 18 2022, 10:11 AM
Sorry. No, with factory preferences everything works fine. Do you have any idea what to change to make it work with my settings?
Pratik Borhade (PratikPB2123) closed this task as Archived.Mar 18 2022, 10:17 AM
Hi, thanks for the update.
Not very sure. Sometimes add-ons, changes in input, navigation preferences may cause this
Issue does not happen with factory prefs so I think we can close this ticket.
Of course, don't hesitate to comment if problem persists with factory preferences.
Ilya Zmetnyy (Led_Astray) changed the task status from Archived to Resolved.Mar 18 2022, 10:18 AM
Pratik Borhade (PratikPB2123) mentioned this in T96789: Slow Response Rotation Gizmo in edit mode.Mar 26 2022, 10:52 AM
