Maniphest T96632
Apply scale on curve does not update values for geometry bevel depth
Closed, Archived
None
Robert S (eobet)
Mar 19 2022, 5:07 PM
  • BF Blender
Philipp Oeser (lichtwerk)
Robert S (eobet)
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.09
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash: rBc77597cd0e15
Worked:
When you make tubes out of curves and then scale them in object mode and apply scale afterwards, you can't match up the bevel depth to other objects because the values are mismatched.
  1. Create a curve
  2. Add a bevel depth to that curve
  3. Scale the curve
  4. Duplicate the curve
  5. Apply scale to the duplicate
  6. Scale the duplicate
  7. Compare the bevel depth values
Result: The values are the same.
Expected: The values should be different.
Workaround: No idea. Visually match, I guess.
Bonus bug: Resolution might suffer from something similar...
Robert S (eobet) created this task.Mar 19 2022, 5:07 PM
Robert S (eobet) updated the task description.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Mar 21 2022, 9:25 AM
This is because the radii are changed when you apply scale.
The resulting geometry is a combination of the bevel depth scaled by the curve points radii, so in order to get a visual match between the two objects, you would have to make sure you have the same radii, too [which you can do e.g. with Alt+S]
Makes sense?
Robert S (eobet) added a comment.Mar 27 2022, 12:13 PM
Makes sense?
Perhaps from a technical standpoint, but from a Ux standpoint it does not.
Philipp Oeser (lichtwerk) closed this task as Archived.Apr 5 2022, 10:52 AM
In T96632#1330587, @Robert S (eobet) wrote:
Makes sense?
Probably not ideal, but afraid this will not be considered a bug.
Thanks for the report, but the issue reported here is a request for modified/improved behavior and not a bug in current behavior. Closing as this bug tracker is only for bugs and errors.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
