Maniphest T96725
Workspace>Filter
Closed, Duplicate
None
William White (Munroman)
Mar 23 2022, 9:26 AM
  • BF Blender
Philipp Oeser (lichtwerk)
Pratik Borhade (PratikPB2123)
Sergey Sharybin (sergey)
Graphics card: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.79
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash: rBc77597cd0e15
Related Objects
Mentioned In
T96680: Light Properties not available
Mentioned Here
rB8344ef73940d: Fix T96524: Regression: The Material Preview doesn't show
William White (Munroman) created this task.Mar 23 2022, 9:26 AM
William White (Munroman) added a comment.Mar 23 2022, 9:30 AM
I initaly reported this error as:-
When adding lights the Properties are not displayed when the "Bulb" is selected. I load the same file in Blender 3 and all is well :-) I have tried this with files created in Blender 3 and also freshly created files in 3.1 with the same result.
However you could not replicate the error. So I did some testing on my own and found If I apply Workspace>Filter the Light properties (as previously described) dissapears. This is regardless of whether I have selected any addons or they are all sitting unselected. I turn the Worlspace>Filter off and the Light properties magically re-appear :-) I hope you find a fix for this soon because my tabs at the side are unreadable :-)
Many Thanks
Bill
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Mar 23 2022, 10:34 AM
Philipp Oeser (lichtwerk) added subscribers: Sergey Sharybin (sergey), Philipp Oeser (lichtwerk).
@Sergey Sharybin (sergey) fixed the preview issue yesterday, see rB8344ef73940d: Fix T96524: Regression: The Material Preview doesn't show
Please check a fresh 3.2 build from https://builder.blender.org/download/daily/ and report back if you can still reproduce your issue in that fresh build.
William White (Munroman) added a comment.Mar 23 2022, 12:40 PM
Sorry guys but the problem persists in 3.2 :-( With workspace Filter checked (with or without any addons checked) the light properties dialogue dissapears from the Bulb tab. All that is left is "Preview" there is then no way to adjust the properties of any light sources added to the scene. Uncheck Workspace>Filter and the lighting properties magically re-appear :-)
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Mar 23 2022, 1:43 PM
Hi @William White (Munroman) , I assume this issue is related (or same) to your previous report: T96680: Light Properties not available
I can not reproduce with your provided steps
  • Add a light source
  • In properties tab- Active tool and workspace settingsWorkspaceFilter
  • With Light object selected, switch to Object data properties (Tabs are still visible for me)
Have you tested with factory settings? : FileDefaultsLoad Factory Settings
William White (Munroman) added a comment.Mar 23 2022, 2:05 PM
Hi Pratik, Yes, it is still the same fault :-) and yes I have tested it with factory settings. It cured it until I tried to filter my workspace, then it was back. I have tried the latest 3.2 alpha...same results. The problem is connected to Workspace>Filter checkbox :-) When unchecked all is well, when workspace>filter checked - no light properties :-) The problem does not exist in Blender 3.0.1 so it is connected some change made to Blender since that version :-) I can send you screenshots or anything else you would like :-)
Pratik Borhade (PratikPB2123) closed this task as a duplicate of T96680: Light Properties not available.Mar 23 2022, 4:29 PM
Pratik Borhade (PratikPB2123) mentioned this in T96680: Light Properties not available.
