Maniphest T96795
Density of volume shader doesn't change/react on input value
Closed, Archived
None
Christoph Duyster (LuckyChris)
Mar 26 2022, 11:00 AM
  • BF Blender
  • Render & Cycles
Brecht Van Lommel (brecht)
Midge Sinnaeve (mantissa)
Philipp Oeser (lichtwerk)
Pratik Borhade (PratikPB2123)
Operating system: macOS-12.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Max Apple 4.1 Metal - 76.3
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
I try to change the density of my volume shader based on the distance of 2 objects.
So i have this GN node tree, which obviously works because the distance value is coming over as you can see if i plugin my shader:
But if i want to see my volume shader....it looks like a constant value. So maybe i am making a stupid mistake or it is a bug...
Christoph Duyster (LuckyChris) created this task.Mar 26 2022, 11:00 AM
Pratik Borhade (PratikPB2123) updated the task description.Mar 28 2022, 7:59 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from Developers.Mar 28 2022, 10:41 AM
Philipp Oeser (lichtwerk) added a project: Render & Cycles.
Philipp Oeser (lichtwerk) added subscribers: Brecht Van Lommel (brecht), Philipp Oeser (lichtwerk).
You cant use face/vertex based information in a volume shader, can you?
The distance in a shader works if you are rendering this on the surface, yes, but not so if done in a volume.
Dont think this has anything to do with the fact this is coming from geometry nodes, same is true for regular textures or vertex colors.
I think this can be closed (@Brecht Van Lommel (brecht): correct me if I am wrong).
Brecht Van Lommel (brecht) closed this task as Archived.EditedMar 29 2022, 7:55 PM
This is a limitation, there is no way to interpolate surface attributes into the volume. In the future there may be geometry nodes that help with that kind of thing, doing it at render time would be expensive.
Philipp Oeser (lichtwerk) added a subscriber: Midge Sinnaeve (mantissa).
