Maniphest T96811
3.1 Initial Lag When Using Rotate and Scale Gizmos
Closed, Duplicate
None
Veily (veilrain)
Mar 27 2022, 4:45 AM
  • BF Blender
Veily (veilrain)
Operating system: macOS 12.2.1
Graphics card: AMD Readon RX 6900 XT 16GB
Broken: 3.1 macOS x86
Worked: 3.0.1 macOS x86
After updating to 3.1, there is a very noticible initial lag when rotating and scaling object with Gizmos (Rotate Tool and Scale Tool). The object does not follow the cursor immediately when I start draging the mouse but only after a short delay. The same behaviour is not observed in move tool. It is also not observed when rotating and scaling with shortcuts.
Open startup project. Select the cube and activate rotate (or scale) tool. Drag the Gizmo to rotate (scale) the object.
Veily (veilrain) created this task.Mar 27 2022, 4:45 AM
Veily (veilrain) added a comment.EditedMar 27 2022, 5:10 AM
Saw T96789, T96591, and T96435. Seems related but they are experiencing the issue on different versions. I am having this issue on 3.1 while they report 3.1 is working for them.
Veily (veilrain) renamed this task from 3.1 Initial Lag When Rotating with Rotate Tool (Rotate Gizmo) to 3.1 Initial Lag When Using Rotate and Scale Gizmos.Mar 27 2022, 5:21 AM
Veily (veilrain) updated the task description.
Veily (veilrain) added a comment.Mar 27 2022, 5:45 AM
Seems unique to macOS, I can reproduce it on two of my Macs but not PC running Windows.
