Broken: (example: 3.2.0 Alpha,08d2428632ed, master, 2022-03-26, as found on the splash screen)
Introduced in rB4b35d6950d4f: Fix T96711: snap in edit mode for selected objects does not work
Snapping is currently broken with proportional editing
Also, The checkbox "Project Individual Elements" functionality is inverted.
It is enabled by default and when I check it to activate it the functionality is disabled.
I'm following this tutorial https://youtu.be/R1isb0x4zYw?t=266 to adapt a surface of an object over another one.
Activating the checkbox I got surfaces intersecting, deactivating it the projections work correctly.
- Open .blend file
- Move selected vertex (snapping is broken)
