See https://developer.blender.org/T96942
When baking normals in tangent space, the normals are relative to the UV map so you can't just copy color values across UV boundaries because it will lead to artifacts.
In this case it would be much better to set the default back to Extend. Or maybe even just disable the Adjacent faces option because it is just not applicable for this specific situation.
