Maniphest T97211
Blender 3.1.0 crashes when highlighting any part of the model
Closed, Duplicate
None
Matéo (Matrepied)
Apr 10 2022, 6:00 AM
  • BF Blender
Matéo (Matrepied)
Pratik Borhade (PratikPB2123)
Operating system: Windows 11 last update
Graphics card: RTX 2060 (laptop)
Blender Version : 3.1.0
Hi ! Thanks you if you have any recommandations, I'm new here !
The software just closes when I try to highlight any part (holding LMB)
Everything works fine until I use a "Subdivision Surface" tool, still no prob for highlighting any part but if you click on "on cage" and then try to highligt/select any thing, it just crashes.
Sorry if the report isn't very clear I'm litteraly using blender for less than 2 hours :).
Matéo (Matrepied) created this task.Apr 10 2022, 6:00 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Apr 11 2022, 7:35 AM
Hi, thanks for the report.
Crash is already fixed on latest 3.2 build and 3.1 corrective release- T96344: GPU subdivision: Crash on select in Edit Mode with X-Ray on and Mirror Modifier
Please test there and report back if you still get the crash
