Operating system: Linux-5.17.1-3-MANJARO-x86_64-with-glibc2.35 64 Bits
Graphics card: AMD Radeon RX 570 Series (POLARIS10, DRM 3.44.0, 5.17.1-3-MANJARO, LLVM 13.0.1) AMD 4.6 (Core Profile) Mesa 21.3.8
Broken: version: 3.1.2, branch: makepkg (modified), commit date: 2022-03-31 17:40, hash: rBcc66d1020c3b
Worked: 2.79
When using a curve with geometry as the rendered item of a hair particle system, the hairs no longer show up. They start appearing if the path is converted to a mesh, which is something the artist will sometimes not want to do. This worked in the latest version of Blender 2.x where I used it before, it likely broke somewhere in Blender 3.x.
Attached is a simple blend that replicates the issue: The plane contains a particle system instancing a collection that contains the path. On its own the curve's geometry can be seen clearly, however the particle system refuses to replicate it. It will show up once you select the curve and use Object - Convert - Mesh.
Create a plane and a curve. Give the curve some depth in its geometry section. Place the curve in a new collection. Create a new particle system on the plane. Set it to hair, in the render section pick to render as a collection, set our curve's collection as the instance collection. The curve should be replicated by each hair yet nothing is seen.
