Maniphest T97857
surface deform and subdivision surface break generated texture coordinate
Closed, Duplicate
None
Adriano D'Elia (aDElia)
May 4 2022, 7:29 PM
  • BF Blender
Kévin Dietrich (kevindietrich)
Graphics card: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: rBcc66d1020c3b
using surface deform and then subdivision surface on a mesh, break generated texture coordinate output.
On a mesh (also the default cube) add a surface deform with a mesh target and then add a subdivision surface.
In shader editor tab add a texture coordinate node and view the generated output.
Switching between the modifier visibility we can see the behaviour on the generated output when surface deform is on or off.
on previous blender version, these steps works fine
Adriano D'Elia (aDElia) created this task.May 4 2022, 7:29 PM
Kévin Dietrich (kevindietrich) added a subscriber: Kévin Dietrich (kevindietrich).May 4 2022, 8:03 PM
This is the same as T96596. You can try a newer build which has a fix for EEVEE at least.
Kévin Dietrich (kevindietrich) closed this task as a duplicate of T96596: GPU subdivision causes problems in generated Texture Coordinate with Cycles.May 4 2022, 8:03 PM
