Maniphest T98570
Regression: Shader AOV doesn't seem to work for World on Cycles
Closed, ResolvedBUG
Brecht Van Lommel (brecht)
Alex P (eneen)
Jun 3 2022, 8:33 AM
  • BF Blender
  • Render & Cycles
  • Cycles
Alex P (eneen)
michael campbell (3di)
Philipp Oeser (lichtwerk)
Pratik Borhade (PratikPB2123)
Stephen Imhoff (Clockwork-Muse)
Operating system: Windows 11
Graphics card: Geforce 1070Ti
Broken: 3.1.2
Worked: 2.93
Caused by rB1df3b5198885: Cycles: replace integrator state argument macros
Shader AOV attached to World shader produces black image when rendered with Cycles (GPU and CPU). It's ok with Eevee.
Open default cube scene. Add AOV output to world, then add Shader AOV with same name in View Layer tab.
Or just load my file and render using Eevee and then switch into Cycles. Cycles render will be completely black.
Revisions and Commits
rB Blender
D15114
Alex P (eneen) created this task.Jun 3 2022, 8:33 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Jun 3 2022, 9:31 AM
Can confirm, will check (think there was a report for this already)
Philipp Oeser (lichtwerk) added a project: Render & Cycles.Jun 3 2022, 10:02 AM
Philipp Oeser (lichtwerk) added a project: Cycles.Jun 3 2022, 11:59 AM
Philipp Oeser (lichtwerk) added a subscriber: Brecht Van Lommel (brecht).
I think this is actually the same as the remaining bits of T93278: Glass renders black in environment pass if Transparent Glass is checked, and custom AOV renders completely black, @Brecht Van Lommel (brecht)?
In this case, think I will merge T93278 into this (this report seems to be a bit simpler)
Philipp Oeser (lichtwerk) renamed this task from Shader AOV doesn't seem to work for World on Cycles to Regression: Shader AOV doesn't seem to work for World on Cycles.Jun 3 2022, 11:59 AM
Philipp Oeser (lichtwerk) triaged this task as High priority.
Philipp Oeser (lichtwerk) updated the task description.
Philipp Oeser (lichtwerk) added subscribers: michael campbell (3di), Stephen Imhoff (Clockwork-Muse), Pratik Borhade (PratikPB2123).
Brecht Van Lommel (brecht) lowered the priority of this task from High to Normal.Jun 3 2022, 12:56 PM
Brecht Van Lommel (brecht) changed the subtype of this task from "Report" to "Bug".Jun 3 2022, 3:50 PM
Brecht Van Lommel (brecht) closed this task as Resolved by committing rB074010ad6d0c: Fix T98570: Cycles AOVs not working in background shader.Jun 3 2022, 4:03 PM
Brecht Van Lommel (brecht) added a commit: rB074010ad6d0c: Fix T98570: Cycles AOVs not working in background shader.
