Maniphest T98615
Regression: Tweak mode broken
Closed, Duplicate
None
Christopher Tyler (Christopher3D)
Jun 5 2022, 6:27 PM
  • BF Blender
  • User Interface
  • Modeling
Pratik Borhade (PratikPB2123)
Operating system:
Graphics card:
Broken: 3.2 build Downloaded June 4th
Worked: 3.1.2 release
In 3.1.2, Tweak mode was used to directly grab an element and operate on it with a given tool. For instance, Edge Slide. In Tweak mode you can grab the selected edge (or loop) and directly slide it without needing to use the widget (which is often way off screen).
In 3.2, Tweak mode always just moves the selected elements.
Here are two videos examples.
  • Open default scene
  • In edit mode -> select bevel tool (or any other)
  • Change to face selection mode
  • Change drag mode to tweak
  • Click and drag over any face
video files:
Related Objects
Mentioned Here
T96885: Regression: Drag Fallback on Tweak is using Move instead
rB0f530b0b03c5: Fix T96885: drag fallback on tweak is using active tool instead
Christopher Tyler (Christopher3D) created this task.Jun 5 2022, 6:27 PM
Christopher Tyler (Christopher3D) updated the task description.Jun 5 2022, 6:30 PM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Jun 6 2022, 5:10 AM
Pratik Borhade (PratikPB2123) added projects: User Interface, Modeling.
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Thanks for the report. I can confirm.
Bisecting...
Pratik Borhade (PratikPB2123) renamed this task from Tweak mode broken in 3.2 to Regression: Tweak mode broken.Jun 6 2022, 5:15 AM
Pratik Borhade (PratikPB2123) updated the task description.
Pratik Borhade (PratikPB2123) changed the task status from Confirmed to Needs Information from Developers.Jun 6 2022, 5:38 AM
Pratik Borhade (PratikPB2123) added a subscriber: Campbell Barton (campbellbarton).
This behavior is probably expected as Campbell said in T96885
In T96885#1351460, @Campbell Barton (campbellbarton) wrote:
Drag is now translating, not rotating - which is expected as tweak's drag action is to translate.
BTW this is caused by rB0f530b0b03c5: Fix T96885: drag fallback on tweak is using active tool instead
@Campbell Barton (campbellbarton) hi, could you take a look at this report?
Is it fair to merge this ticket in T96885
Christopher Tyler (Christopher3D) added a comment.Jun 23 2022, 5:05 PM
I downloaded the 3.2.1 version, and Tweak is still broken. It only moves instead of using the current tool. For instance, Edge Slide, when I try and use Tweak mode it just moves the selected edges instead of sliding them. This is a big problem. It worked correctly in 3.1.
Campbell Barton (campbellbarton) closed this task as a duplicate of T96885: Regression: Drag Fallback on Tweak is using Move instead.Aug 12 2022, 5:48 AM
