Maniphest T98732
vertex select crash
Closed, Duplicate
None
trong ta (herubi)
Jun 9 2022, 3:08 PM
  • BF Blender
Omar Emara (OmarSquircleArt)
Pratik Borhade (PratikPB2123)
trong ta (herubi)
Operating system: win11 64-bit (10.0, build 22000 )
Graphics card: nvidia geforce gtx 1650 ti
Broken: 3.1
blender get crash when i select vertex in X-ray mode
Open X-ray mode and try to use select box/circle
Based on t{F13141667}he default startup or an attached .blend file (as simple as possible).
trong ta (herubi) created this task.Jun 9 2022, 3:08 PM
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Jun 9 2022, 3:28 PM
Omar Emara (OmarSquircleArt) edited projects, added BF Blender; removed Add-ons (Community).
Omar Emara (OmarSquircleArt) added a subscriber: Omar Emara (OmarSquircleArt).
Can you test on the latest build? As 3.1 is no longer receiving fixes. https://builder.blender.org/
Please open Blender's installation directory and double click on the blender_debug_gpu.cmd. This will start Blender in debug mode and create log files. Try to reproduce the error again. Once it crashes or you close Blender manually the Windows Explorer should open and show you up to two files, a debug log and the system information. Add them to your bug report by clicking on the upload button as shown in the screenshot below or via drag and drop. Please also upload the crash log located in C:\Users\[your username]\AppData\Local\Temp\[project name].crash.txt (or simply type %TEMP% into the path bar of the Windows Explorer).
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Jun 10 2022, 5:07 AM
Crash has been fixed already. see: T96344: GPU subdivision: Crash on select in Edit Mode with X-Ray on and Mirror Modifier
As Omar said, download and test in latest builds
