Maniphest T98891
Surface Deform modifier ignores shapekeys
Closed, Duplicate
None
kursad k (kursadk)
Jun 14 2022, 7:00 PM
  • BF Blender
Germano Cavalcante (mano-wii)
kursad k (kursadk)
Operating system: win 11
Broken: 67f5596f194c
It is not possible to edit shapekeys if the object has a Surface Deform modifier applied. This does not seem to be an issue with the Mesh Deform modifier.
Load the attached .blend file
Select the torus object and make sure "Key 1" is selected
Change to edit or sculpt mode and try to modify the mesh
Related Objects
Mentioned Here
T54397: “Surface Deform”-modifier is overwriting the whole modifier stack
rB67f5596f194c: Fix T98866: GPU subdiv crash in edit mode with loose geometry
kursad k (kursadk) created this task.Jun 14 2022, 7:00 PM
kursad k (kursadk) updated the task description.Jun 14 2022, 7:02 PM
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).Jun 16 2022, 12:53 AM
Thanks for the report,
However, this is the same problem reported in T54397: “Surface Deform”-modifier is overwriting the whole modifier stack (as shapekeys work like a modifier that is at the top of the stack).
So I will merge the reports.
Germano Cavalcante (mano-wii) closed this task as a duplicate of T54397: “Surface Deform”-modifier is overwriting the whole modifier stack.Jun 16 2022, 12:53 AM
