Maniphest T98990
Shader editor: no Undo in Edit mode or Texture Paint mode
Closed, Duplicate
None
Georg K (georg)
Jun 19 2022, 6:05 PM
  • BF Blender
Georg K (georg)
Pratik Borhade (PratikPB2123)
Operating system: Linux-5.17.15-1-MANJARO-x86_64-with-glibc2.35 64 Bits
Graphics card: AMD VERDE (LLVM 13.0.1, DRM 2.50, 5.17.15-1-MANJARO) AMD 4.5 (Core Profile) Mesa 22.1.1
Broken: 3.0.1, version: 3.3.0 Alpha, branch: master, commit date: 2022-06-18 22:14, hash: rB575884b82786
In Edit or Texture Paint mode, undo does not work in the Shader editor. Sometimes, undo stops having any effect on the nodes, sometimes it just takes multiple undos to undo a single change (no reproducible example for that at the moment). I'm using global undo.
In the default scene,
  • enter edit mode
  • open a shader editor
  • select the Principled BSDF node and either
    • Alt-drag to disconnect it from the Material Output node
    • or add a label to the node
    • or add a brick texture node and connect it to the Principled BSDF color input
    • or deleting the Principled BSDF
  • 4x Ctrl-Z takes you out of edit mode (2x undo in case of the changed label) but does not reconnect the Principled BSDF to the Material output (if you are in Object mode, pressing once will reconnect the nodes) or return the label to its prior state
In Texture Paint mode, undo will not take you back to object mode.
Georg K (georg) created this task.Jun 19 2022, 6:05 PM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Jun 20 2022, 4:54 AM
Hi, thanks for reporting. But this issue is already reported in T71895: Undo doesn't consider changes in nodetree when object is in edit and texture paint mode
Will merge your report in existing one.
