Maniphest T100473
Problem Undoing in geometry nodes while using Edit mode
Closed, Duplicate
None
Shmuel Israel (shmuel)
Aug 18 2022, 2:11 AM
  • BF Blender
  • Geometry Nodes
  • Undo
Blender Version:
I'm using 3.4, but it always had this issue even in other versions
Description:
If you are working in the geometry nodes editor and enter in edit mode on that object or another object. if you try undoing [ctrl z] it will take you back to the state the node tree was in when you changed modes, after pressing undo [ctrl z] the amount of times as actions you did since you changed modes.
this is a long standing problem and I never remember it ever working properly.
Shmuel Israel (shmuel) created this task.Aug 18 2022, 2:11 AM
Shmuel Israel (shmuel) added projects: Geometry Nodes, Undo.
