Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
when I went to rotate, it only did the blue way, or in other words, it just turns around in circles. I need to other directions, but it only did the blue way. Also, when I import an object, it doesn't go on the grid. It goes FAR away from the gird and some parts, the tools don't show up next to the object. the rotate tool would be far away from the object, and I had to move it back and forth to see where it was going. Please fix!!
Thank you!
