Julien Kaspar wrote (copied from chat):
I checked out D14589 GPencil: New Automasking Strokes for Sculpt recently.
I think this feature could use some needed improvements to make it more consistent and just as useful as the mesh sculpt mode auto-masking options:
First off, "Stroke" auto-masking requires too much precisions. You need to click direclty on the stroke to make the brush have an effect. It would be better if the nearest stroke to the cursor position would be detected, similar to selecting.
"Layer" and "Material" auto-masking does not at all behave like auto-masking. Currently when these options are enabled it will look at which layer/material is active and will only affect those.
But auto-masking should not work based on any active layer or material, but instead based on what is under the cursor when the stroke is started. It is a feature to dynamically auto-mask areas of the object on each stroke, not a static mask that you set beforehand.
Also, the use case of the current auto-masking behaviour was already covered with auto-locking layers and selecting all strokes of a material.
I suggest to change the behaviour to make it more consistent with mesh sculpt mode auto-masking.
Lastly, the auto-masking toggles are right right now only presented as brush options. While mesh sculpt mode also has them as brush options, it is not the primary intended way to use this feature! The brush auto-masking is purely to define a custom brush preset. It's a corner case feature.
The proper way to access and toggle auto-masking options is via the Alt A pie menu, to toggle them for the entire sculpt mode.
This way any brush or tool is able to use auto-masking and it's very convenient to toggle on/off.
The way it currently behaves in grease pencil forces the user to toggle the auto-masking options for each brush individually, which ends up being tedious and leads to many auto-masking toggles left enabled accidental when switching brushes.
I don't have a good suggestion for a pie menu shortcut at the moment since Alt A is already taken. I also noticed that there are no mode "Options" in grease pencil, like in mesh sculpt mode.
I would like to create a task to add the mode auto-masking options to the center of the header, in both grease pencil and mesh sculpt mode to make them more accessible in both modes and present them as the primary way to use auto-masking.
More information about the layout design here: T101593
Automasking
- Move Automasking to GPencil global area.
- Add new Automasking by Stroke Layer.
- Add new Automasking by Stroke Material.
Unified
- Create new unified struct.
