Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.65
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash: rB0759f671ce1f
1- after adding an Empty hair to an object causes the object to lag miserably slow when move and drag in the viewport...
2- while entering edit mode, a lag is noticeable, but it becomes worst when using lasso select and then select some random bigger or small portion of the mesh, it takes a few seconds to select anything in edit mode in this model provided, and when i unselect with A what i selected before with the lasso tool it seems to be no lag, and then the worst part that made me not use this version of blender for this project at the moment is that when i press A to select all in edit mode, blender freezes forever and causes my pc to be at 90-100 % of cpu usage for some stupid select all maneuver...
3- i checked doing the same issue from 1 with the default cube instead from my startup file, then i subdivided 15 times the cube in edit mode and i noticed a strange lag if the object has 3 or more levels additional of subdivision (but from subdiv modifier and gets about 100 k faces which is really nothing to lag like that), though without any empty hair attached to it, it moves and drags fast as usual...
- Open attached .blend file
- Select object fox-girl-body-1
- Add → Curve → Empty Hair
- move the object fox-girl-body-1
