Maniphest T101432
artifacts when making a 2160x3840 mp4 video using the blender video sequencer
Closed, Archived
None
AR (arc4g)
Sep 28 2022, 12:59 PM
  • BF Blender
  • Video Sequencer
AR (arc4g)
Omar Emara (OmarSquircleArt)
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 517.48
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash: rB0759f671ce1f
artifacts when making a 2160x3840 video (vertical 4k) using the blender video sequencer mp4 container
render a 2160x3840 image sequence then try making a 2160x3840 mp4 video out of it using the blender video sequencer
video result
blend file to create the render
blend file i use to create the video
it seems like it's something to do with missing I-frames, I fixed the issue by setting keyframe intervals to 0 but that makes the file size quite large
AR (arc4g) created this task.Sep 28 2022, 12:59 PM
AR (arc4g) renamed this task from artifacts when making a 2160x3840 mp4 video to artifacts when making a 2160x3840 mp4 video using the blender video sequencer .Sep 28 2022, 1:12 PM
AR (arc4g) added a project: Video Sequencer.
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Sep 28 2022, 2:01 PM
Omar Emara (OmarSquircleArt) added a subscriber: Omar Emara (OmarSquircleArt).
Can you clarify what are the artifacts in this video? It seems to be consistent with the render.
AR (arc4g) added a comment.Sep 28 2022, 2:18 PM
The viewer you might be using might be automatically fixing it for you, here is what I see
i also see it when I play it locally with vlc or mpc
Omar Emara (OmarSquircleArt) added a comment.Sep 28 2022, 2:21 PM
Chromium, MPV, and Blender all display it correctly on my side. Are you sure this isn't a decoding issue on your viewer? Maybe hardware acceleration issues? Does disabling that fixes the issue?
AR (arc4g) added a comment.Sep 28 2022, 2:40 PM
You are right it seems to be on my side, i turned off hardware acceleration in chrome and the embedded video played without issues, it might be a faulty gpu driver or my gpu is broken
Omar Emara (OmarSquircleArt) closed this task as Archived.Sep 28 2022, 2:42 PM
Most likely a driver issues. Hardware acceleration is rather flaky.
