Maniphest T101522
Motion Paths: 'Update Paths' inconveniently restores frame range
Closed, ResolvedBUG
Sybren A. Stüvel (sybren)
No Name (legendboyAni)
Oct 1 2022, 1:31 PM
  • BF Blender
  • Animation & Rigging
Brad Clark (RiggingDojo)
Colin Marmond (Kdaf)
Germano Cavalcante (mano-wii)
user1 (user1)
Operating system: Linux-5.19.10-1-default-x86_64-with-glibc2.33 64 Bits
Graphics card: NVIDIA GeForce RTX 3060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 515.65.01
Broken: version: 3.2.0, caused by rB4e57b6ce77b1: Animation: Sensible frame range for motion paths
Worked: (3.1)
If there is already a motion path, editing its frame range and then clicking "Update" overwrites those edits.
  • Open attached .blend file
  • In the Properties editor, go to Object PropertiesMotion Paths and change the Frame End value to 30
  • Click Update Paths
  • See that the end frame jumps back to 250.
Revisions and Commits
rB Blender
Related Objects
Mentioned In
rBM9823: Anim: improve motion paths documentation
Mentioned Here
No Name (legendboyAni) created this task.Oct 1 2022, 1:31 PM
No Name (legendboyAni) updated the task description.
user1 (user1) changed the task status from Needs Triage to Needs Information from User.Oct 1 2022, 1:53 PM
user1 (user1) added a subscriber: user1 (user1).
can you please share an example blend file, and maybe some screenshots or -records (before/after)?
No Name (legendboyAni) added a comment.Oct 1 2022, 3:34 PM
{F13602591}ok hear is the video that shows what is wrong with new motion path
No Name (legendboyAni) added a comment.Oct 2 2022, 1:25 PM
hey any update on it i added the video as well
Pratik Borhade (PratikPB2123) renamed this task from NEW motion path sucks to Problem in NEW motion path.Oct 6 2022, 8:28 AM
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Needs Triage.
Pratik Borhade (PratikPB2123) updated the task description.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Oct 6 2022, 5:02 PM
Germano Cavalcante (mano-wii) added a project: Animation & Rigging.
Germano Cavalcante (mano-wii) added subscribers: Colin Marmond (Kdaf), Sybren A. Stüvel (sybren), Germano Cavalcante (mano-wii).
Caused by rB4e57b6ce77b1: Animation: Sensible frame range for motion paths
Cc. @Colin Marmond (Kdaf), @Sybren A. Stüvel (sybren)
Germano Cavalcante (mano-wii) renamed this task from Problem in NEW motion path to Motion Paths: 'Update Paths' inconveniently restores frame range.Oct 6 2022, 5:03 PM
Germano Cavalcante (mano-wii) updated the task description.
Brad Clark (RiggingDojo) added a subscriber: Brad Clark (RiggingDojo).Oct 6 2022, 5:27 PM
For now the best option would be to select the keys you want the range to update for so it updates around that range. I do agree that the option to use the set range instead of always use scene frame range to update isn't ideal. The other options should be there + use the range settings from the Motion Path Panel.
Sybren A. Stüvel (sybren) updated the task description.Dec 8 2022, 4:30 PM
I agree this is an issue, but I did remove the drama from the description.
Sybren A. Stüvel (sybren) closed this task as Resolved by committing rBd72c7eefd1c5: Fix T101522: Animation: motion path range overwritten by 'Update Paths'.Dec 12 2022, 5:37 PM
Sybren A. Stüvel (sybren) claimed this task.
Sybren A. Stüvel (sybren) added a commit: rBd72c7eefd1c5: Fix T101522: Animation: motion path range overwritten by 'Update Paths'.
Sybren A. Stüvel (sybren) mentioned this in rBM9823: Anim: improve motion paths documentation.Dec 22 2022, 11:10 AM
