Maniphest T101575
viewer node overlay doesn't save with saved file
Closed, Resolved
None
Shmuel Israel (shmuel)
Oct 3 2022, 10:13 PM
  • BF Blender
  • EEVEE & Viewport
  • Geometry Nodes
Jacques Lucke (JacquesLucke)
Pratik Borhade (PratikPB2123)
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2070 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.78
Broken: version: 3.4.0 Alpha, branch: master, commit date: 2022-09-29 01:57, hash: rBe2df1958449a
Worked: never
If we change viewer node overlap value or disable it and save the file. Reopening the file resets it value to 1.
  • open file,
  • set the overlay as off,
  • save file or save it as default startup file
  • Reopen file
Shmuel Israel (shmuel) created this task.Oct 3 2022, 10:13 PM
Shmuel Israel (shmuel) added projects: EEVEE & Viewport, Geometry Nodes.
Shmuel Israel (shmuel) updated the task description.Oct 3 2022, 10:17 PM
Shmuel Israel (shmuel) renamed this task from GN viewer node overlay doesn't save with default blend to viewer node overlay doesn't save with default blend.Oct 3 2022, 10:20 PM
Shmuel Israel (shmuel) renamed this task from viewer node overlay doesn't save with default blend to viewer node overlay doesn't save with default blend startup.
Pratik Borhade (PratikPB2123) renamed this task from viewer node overlay doesn't save with default blend startup to viewer node overlay doesn't save with saved file.Oct 4 2022, 4:00 AM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.
Pratik Borhade (PratikPB2123) updated the task description.
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).Nov 11 2022, 1:46 PM
Can you still reproduce it? It was likely fixed by a subversion bump.
Shmuel Israel (shmuel) added a comment.Nov 13 2022, 3:26 AM
it was fixed pretty quickly from when I made the report
Iliya Katueshenock (Moder) closed this task as Archived.Nov 13 2022, 3:30 AM
Pratik Borhade (PratikPB2123) changed the task status from Archived to Resolved.Nov 13 2022, 8:28 AM
