Maniphest T101668
Linked data-block has "pointer" property still active
Confirmed, NormalBUG
Julian Eisel (Severin)
Dalai Felinto (dfelinto)
Oct 7 2022, 11:06 AM
  • BF Blender
  • User Interface
Bastien Montagne (mont29)
Broken: version: 3.4.0 Alpha, branch: Unknown, commit date: Unknown Unknown, hash: rBUnknown
Worked: Probably never
Open torus.blend. It has a linked collection containing the selected object Torus.
As you can see in the image, the "Object" rna properties (parent, and the array modifier one) are both active:
In fact you can even click on the property to change it (the popup show up, but clicking on it at least doesn't change it):
Dalai Felinto (dfelinto) changed the task status from Needs Triage to Confirmed.Oct 7 2022, 11:06 AM
Dalai Felinto (dfelinto) created this task.
Dalai Felinto (dfelinto) added a project: User Interface.
Note that the same happens for other pointers: T101667.
Bastien Montagne (mont29) assigned this task to Julian Eisel (Severin).Oct 7 2022, 6:29 PM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".
Bastien Montagne (mont29) added subscribers: Julian Eisel (Severin), Bastien Montagne (mont29).
This is caused by rB7fed4c06c2ff45, which forcefully clears the DISABLED flag on the button... @Julian Eisel (Severin) Think that one is for you, not really clear to me in which case ui_but_add_search could be called more than once on a same button?
