Maniphest T101818
Viewer node doesn't display correctly added Alpha channel in Combine RGBA node
Closed, Archived
None
Corrado Piscitelli (GigiSpligi)
Oct 14 2022, 11:20 AM
  • BF Blender
Ivan Cappiello (icappiello)
Jeroen Bakker (jbakker)
Omar Emara (OmarSquircleArt)
Operating system: macOS-12.6-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro Vega 64 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.8.101
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash: rBb292cfe5a936
Worked: (N/A)
When combining a separate RGBA and a combine RGBA nodes to manually input a different alpha channel on an image, the resulting expected output from the viewer node connected to combine RGBA node should be RGB from input A and alpha from input B, but it seems instead the inputed alpha is not processed correctly or ignored.
Alpha seems to be applied correctly when more compositing is applied afterwards or image is saved to a file (png).
Expected result
Actual result
Open the attached blender file, click render and look at the viewer node in the compositor.
Checked in 2.93 it seems to also work in the same way. Included a 2.93 version for you to see.
Corrado Piscitelli (GigiSpligi) created this task.Oct 14 2022, 11:20 AM
Corrado Piscitelli (GigiSpligi) added subscribers: Ivan Cappiello (icappiello), Jeroen Bakker (jbakker).
Omar Emara (OmarSquircleArt) closed this task as Archived.Oct 14 2022, 12:53 PM
Omar Emara (OmarSquircleArt) added a subscriber: Omar Emara (OmarSquircleArt).
This is just how Blender views zero alpha when the pixel has color data, see for instance T81199. But the actual data is correct.
To get the result you expect, just premultiply the alpha, which is what happens when you save the image.
