Maniphest T101976
batch_for_shader fails with empty positions list on 3.4
Closed, Duplicate
None
Sergey Kritskiy (kritskiy)
Oct 21 2022, 2:02 PM
  • BF Blender
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.01
Broken: version: 3.4.0 Alpha, branch: master, commit date: 2022-10-21 00:31, hash: rBdc09cc13ea49
Worked: 3.3.0 and before
When an empty list of positions is used in batch_for_shader pos property (for example batch_for_shader(shader, 'LINE_STRIP', {"pos": []}) modules\gpu_extras\batch.py throws errors.
  • open the attached .blend, it contains a slightly modified version of the operator_modal_draw.py (Modal Draw) python template;
  • it's modified to add points to self.mouse_path on left mouse click instead of mousemove, this way self.mouse_path starts empty;
  • run the code to register the operator;
  • run the operator (Simple Modal View3D Operator)
  • notice errors in console:
mouse points 0
  File "D:\temp\del\batch_for_shader_issue.blend\Text", line 21, in draw_callback_px
  File "c:\Program Files\Blender Foundation\blender-3.4.0-alpha-scripts\3.4\scripts\modules\gpu_extras\batch.py", line 62, in batch_for_shader
    attr_len = recommended_attr_len(name)
  File "c:\Program Files\Blender Foundation\blender-3.4.0-alpha-scripts\3.4\scripts\modules\gpu_extras\batch.py", line 37, in recommended_attr_len
    item = content[attr_name][0]
IndexError: list index out of range
  • after the first click when a coordinate is added to self.mouse_path errors disappear;
  • running the same code in 3.3 doesn't produce errors
Sergey Kritskiy (kritskiy) created this task.Oct 21 2022, 2:02 PM
Germano Cavalcante (mano-wii) closed this task as a duplicate of T101244: Empty point list in shader batch creation cause error.Oct 21 2022, 7:08 PM
