Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 522.30
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash: rBb292cfe5a936
It seems as though it is not possible to drive the values on a principled volume node using an attribute output from geometry nodes.
It is possible to drive the the principled volume using a custom property on the object.
It is possible to drive the values on surface shaders such as the diffuse bsdf using an attribute output from geonodes.
- Create geonodes nodetree on an object
- Create an output attribute (float)
- Connect the output socket to the group input of the genodes nodetree for ease of numerical input
- Create a material for the object
- Delete the principled BSDF node
- Create a principled volume node and connect to the volume output of the shader nodetree
- Use the geonodes output value as an attribute in the shader nodetree and connect to the density input of the principled volume
- Edit the value of the geonodes attribute, the volume density does not change
---extra---
- Create a custom property for the object
- Use the custom property 'prop' or similar as the input for the volume density
- Set type to Object
- Varying the custom property does change the density
