Maniphest T102546
Blender will crash when clicking on shading viewport
Closed, Duplicate
None
Phillipe L (PhillipeL)
Nov 16 2022, 4:20 AM
  • BF Blender
Germano Cavalcante (mano-wii)
Operating system: Windows-10-10.0.22621 64 Bits
Graphics card: AMD Radeon RX 6600 XT ATI Technologies Inc. 4.5.0 Core Profile Context 22.20.18.220726
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash: rBb292cfe5a936
No matter what I do whenever I click on the "Shading" tab, or try to go into the Render viewport for Eevee my blender closes. Im not even sure if its a crash, it just immediately closes.
If I load of a scene with a model that has more than 200 faces, blender closes. I can open the Render Viewport if im in Cycles, but the shaded viewport still wont work and will close the file immediately. I've restarted my computer, checked the memory cache and I still have room I think, and my computer is brand new. I also tried seeing if there was a crash log for blender but nothing shows up. I even uninstalled and reinstalled Blender. This happens on all files of Blender I open. This started today after having no problems ever.
I have no idea how this happed to begin with. I was working on a butterfly scene with just a low poly butterfly, and transparent background. I had a 2k res hdri background for lighting
Phillipe L (PhillipeL) created this task.Nov 16 2022, 4:20 AM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Nov 17 2022, 2:07 PM
Germano Cavalcante (mano-wii) updated the task description.
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).
I can't reproduce the crash with the attached file.
Please open Blender's installation directory and double click on the blender_debug_gpu.cmd. This will start Blender in debug mode and create log files.
Try to reproduce the error again.
Once it crashes the Windows Explorer should open and show you up to two files, a debug log and the system information.
Add them to your bug report by clicking on the upload button as shown in the screenshot below or via drag and drop.
Please also upload the crash log located in C:\Users\[your username]\AppData\Local\Temp\[project name].crash.txt (or simply type %TEMP% into the path bar of the Windows Explorer).
Phillipe L (PhillipeL) added a comment.Nov 28 2022, 6:16 PM
Sorry for the Late response I was finally able to get the Crash Logs
Thomas Dinges (dingto) changed the task status from Needs Information from User to Needs Triage.Dec 14 2022, 4:31 PM
Germano Cavalcante (mano-wii) added a comment.Dec 15 2022, 7:13 PM
There are shader compilation error messages:
ERROR (gpu.shader): GPU_material_compile VertShader:
    1 | #version 430
      | '#extension' : extension not supported: GL_AMD_vertex_shader_layer
      | #version 430
      | Error: 'closure_eval' : function already has a body
      | #version 430
      | Error: '' : compilation terminated
    2 | #extension GL_ARB_texture_gather: enable
      | Error: compilation errors.  No code generated.
ERROR (gpu.shader): GPU_material_compile FragShader:
    1 | #version 430
      | #version 430
      | #version 430
It is the same error described in: T101675: Material preview and rendered buttons crashes the program.
Germano Cavalcante (mano-wii) closed this task as a duplicate of T101675: Material preview and rendered buttons crashes the program..Dec 15 2022, 7:13 PM
