Maniphest T102754
NLA Editor Scale does not effect playback scale (speed)
Closed, Duplicate
None
Hector DeAnda (Hector123)
Nov 25 2022, 12:11 AM
  • BF Blender
Pratik Borhade (PratikPB2123)
TheRedWaxPolice (TheRedWaxPolice)
Operating system: macOS-12.6.1-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon HD - FirePro D500 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.8.101
Broken: version: 3.5.0 Alpha, branch: master, commit date: 2022-11-23 18:35, hash: rBf4e1f62c62e6
Worked: I tried different version and all have same issue.
In the NLA editor if I press "S" to scale a strip this should scale the playback speed as well, but it does not.
In the NLA editor if I press "S" to scale a strip this should scale the playback speed as well, but it does not. Example: I select a strip, press "S", drag right edge to double original length. Play the animation. The animation still plays at original speed. If I go to the Action Clip panel on the right and change the Playback Scale I can change the strip length and playback speed successfully. If I previously changed the strip length using scale "S" and then go to Action Clip panel on the right and increment the Playback Scale a tenth it will suddenly overwrite the change I just made with the "S" shortcut.
Hector DeAnda (Hector123) created this task.Nov 25 2022, 12:11 AM
TheRedWaxPolice (TheRedWaxPolice) added a subscriber: TheRedWaxPolice (TheRedWaxPolice).Nov 25 2022, 2:21 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Nov 25 2022, 8:50 AM
Hi, thanks for the report. I can reproduce too.
Looks like a regression which has been reported already. see: T101130: Regression: Scaling of NLA Strip Via S Hotkey Not Working
I'll merge your report in existing ticket
Pratik Borhade (PratikPB2123) closed this task as a duplicate of T101130: Regression: Scaling of NLA Strip Via S Hotkey Not Working.Nov 25 2022, 8:51 AM
