Maniphest T103632
Regression: Trim Curve at 100% Causing Jumping of vertices away from the original position
Closed, ResolvedBUG
Mattias Fredriksson (Osares)
Gerstmann Bradley (Bradley_G)
Jan 4 2023, 10:43 AM
  • BF Blender
  • Nodes & Physics
  • Geometry Nodes
Hans Goudey (HooglyBoogly)
Philipp Oeser (lichtwerk)
Thomas Dinges (dingto)
Operating system: Windows-10-10.0.17134-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.11
Broken: version: 3.4.1, branch: blender-v3.4-release, commit date: 2022-12-20 08:50, hash: rBef9ca44dee7f
Worked: 3.3.2, branch: master, commit date: 2022-12-07 12:12, hash: rBbd3a7b41e2b3
Behavior changed in rB11f6c65e61a2: Geometry Nodes: Trim curve node selection input and corrections
This bug is newly introduced in 3.4
Revisions and Commits
rB Blender
D17003
Related Objects
Mentioned In
rBL63174: Geometry Nodes: Add test for trim curves last single point
D17003: Fix T103632: Single point trim should sample curve end point correctly
Mentioned Here
T101379: Regression: Trim curve make spline disapear.
Gerstmann Bradley (Bradley_G) created this task.Jan 4 2023, 10:43 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Jan 4 2023, 2:57 PM
Philipp Oeser (lichtwerk) added projects: Nodes & Physics, Geometry Nodes.
Philipp Oeser (lichtwerk) added subscribers: Hans Goudey (HooglyBoogly), Philipp Oeser (lichtwerk).
From the commit message:
Correct trim for cyclical curves mentioned in T101379, splitting the
curves if the start/endpoint is at the 'loop point'.
But since this was only intended for cyclic curves, I assume this is not an intended change in behavior in this case @Hans Goudey (HooglyBoogly) ?
Philipp Oeser (lichtwerk) renamed this task from Trim Curve at 100% Causing Jumping of vertices away from the original position to Regression: Trim Curve at 100% Causing Jumping of vertices away from the original position.Jan 4 2023, 2:57 PM
Philipp Oeser (lichtwerk) triaged this task as High priority.
Philipp Oeser (lichtwerk) updated the task description.
Thomas Dinges (dingto) added subscribers: Mattias Fredriksson (Osares), Thomas Dinges (dingto).Fri, Jan 13, 3:24 PM
@Mattias Fredriksson (Osares) @Hans Goudey (HooglyBoogly) Can you please look at this high priority report? Thanks in advance.
Hans Goudey (HooglyBoogly) moved this task from Backlog/Bugs to Next Release Targets on the Geometry Nodes board.Fri, Jan 13, 11:41 PM
Hans Goudey (HooglyBoogly) moved this task from Next Release Targets to Backlog/Bugs on the Geometry Nodes board.
Mattias Fredriksson (Osares) claimed this task.Sun, Jan 15, 5:27 PM
Hans Goudey (HooglyBoogly) changed the subtype of this task from "Report" to "Bug".Mon, Jan 16, 7:14 PM
Hans Goudey (HooglyBoogly) closed this task as Resolved by committing rBc55767b32ee1: Fix T103632: Single point trim samples curve end point incorrectly.Mon, Jan 16, 7:38 PM
Hans Goudey (HooglyBoogly) added a commit: rBc55767b32ee1: Fix T103632: Single point trim samples curve end point incorrectly.
Hans Goudey (HooglyBoogly) mentioned this in rBL63174: Geometry Nodes: Add test for trim curves last single point.
