Maniphest T103665
Blender Crashing Whenever It Tries To Access Eevee
Closed, Duplicate
None
Ads Boros (That1Guy592)
Jan 5 2023, 5:01 PM
  • BF Blender
Evan Wilson (EAW)
Broken: 3.4.1
Worked: none (I tried 3.3, and it also crashed)
Whenever I try to use anything relating to Eevee blender crashes. It happens when I try to enter material mode, or render anything in eevee, it also crashes whenever I try to enter the shading tab. I've just got a new computer and have been running tests on it, I found that whenever I try to use GPU cycles rendering it still uses my CPU primarily which I thought was odd, I dont know if this is related or not, but when I looked in the error logs when Blender crashed with Eevee it seemed like there was a communication issue between the drivers, blender, and my GPU. The error logs are included below
  1. Debug logs
  1. Debug GPU
  1. Debug GPU Glitch Work Around
  1. Open up the shading tab
  2. Render anything through Eevee
  3. Switch to material view
This happens on any file I have, so I've just attached my most recent blender file
Ads Boros (That1Guy592) created this task.Jan 5 2023, 5:01 PM
Evan Wilson (EAW) added a subscriber: Evan Wilson (EAW).Jan 6 2023, 7:09 AM
Thank you for the Report.
The errors match those of T101675: Material preview and rendered buttons crashes the program..
It seems updating your GPU driver should fix the issue.
I'll merge your report into that one.
Let us know if updating your driver doesn't fix the issue.
