Maniphest T103919
Make Instances Real not working for different kinds of Instances in Geometry Nodes
Closed, Duplicate
None
Soeren Schmidt-Clausen (soerensc_)
Mon, Jan 16, 2:16 PM
  • BF Blender
  • Nodes & Physics
  • Geometry Nodes
  • Modeling
Operating system: Windows-10-10.0.19045-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 527.56
Broken: version: 3.5.0 Alpha, branch: master, commit date: 2023-01-16 11:23, hash: rB5320372c3452
Worked: None
When Applying "Make Instances Real" on a Geomery Nodes Modiffier that instances different object, it behaves strange and does not work as expected. It Instances itself to the positions of the actuall instances.
Right: The Geometry Nodes Object
Left: Two Objects that are being instanced.
After the Applying "Makei Instances Real" (I moved the objects away from each other for clarity)
  1. Select "Instancer" Object
  2. F3
  3. Make Instances Real (Both Operators do the same)
Simple Setup:
For me this is a huge problem, because I think there is no other way to extract the instances from Geometry Nodes, so you can export them to other programs
Soeren Schmidt-Clausen (soerensc_) created this task.Mon, Jan 16, 2:16 PM
Soeren Schmidt-Clausen (soerensc_) updated the task description.
Iliya Katueshenock (Moder) changed the task status from Needs Triage to Confirmed.Mon, Jan 16, 2:19 PM
Iliya Katueshenock (Moder) added projects: Nodes & Physics, Geometry Nodes, Modeling.
Soeren Schmidt-Clausen (soerensc_) changed the task status from Confirmed to Needs Triage.Mon, Jan 16, 2:21 PM
Soeren Schmidt-Clausen (soerensc_) changed the task status from Needs Triage to Confirmed.Mon, Jan 16, 3:00 PM
Iliya Katueshenock (Moder) closed this task as a duplicate of T93903: Make Instances Real doesn't work for geometry instances.Mon, Jan 16, 5:12 PM
